Hot Rods Stock 41 ford v8
Discussion in 'The Hokey Ass Message Board' started by kitcarco, Aug 28, 2013.
  1. kitcarco
    kitcarco
    from texas
    41 ford with flathead clutch shutters when taking off. What causes this problem
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Very common. Do you still have the 2 rods that run from frame to the engine in the bellhousing area? If not that is the problem ,if so make sure they are tight and all bushings etc are there. The cause is the engine moves back and forth as the clutch is engaged which makes the clutch grab and release making the chatter. If all the rods parts are in order you may need a new clutch ***y ,a disk at the least.
