Technical Stock holes in '32 ford Firewall
Discussion in 'Traditional Hot Rods' started by terry k, Nov 29, 2016.
  1. terry k
    terry k
    from toledo oh
    Any body have a photo of a stock '32 firewall ?? I have a original firewall, but all of the holes have been filled. I'm using the stock dash tunnel and would like to return all holes. Thanks Terry
  2. krylon32
    krylon32
    from Nebraska
    The 3 dimpled in holes on each side of center hold the stock dash. The holes to hold the dash are in the center. of the dimples.
  3. swifty
    swifty
    Have the dimples in the firewall been filled or just the holes for the dash tunnel welded up? Without looking at one there are about 6 or 7 dimples and that's where the holes go. Will have a look in a minute and confirm.
    krylon32 was quicker than me LOL
  4. krylon32
    krylon32
    from Nebraska
    The 3 holes on each side are in a 1/2 moon configuration
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
  6. X38
    X38
    As a piece of Ford trivia/fact, what we all call the firewall, Ford called the dash when those cars came out.
    So when you look up original Ford literature for the deuce, when they refer to the dash, they mean the firewall, o.k.;)
    hotroddon likes this.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
  8. Dak Rat
    Dak Rat
    from NoDak
    If you have access to a Bob Drake catalog, there is a picture of a stock firewall with all the original holes. He sells a grommet kit for all those holes in the various sizes.
    LOU WELLS likes this.
  9. Google "1932 Ford Firewall" and you will get an idea of what you are looking for, they look like Swiss cheese. See page
    11-3 thru 11-5 of "The 1932 Ford Book" if you want the real story. Also try asking on fordbarn.com.
    Charlie Stephens
  10. terry k
    terry k
    from toledo oh
    I have the dimpled holes drilled. Thanks for the help !!
  11. If it is the drawing I remember from years ago the holes that did not require grommets were not marked (like the ones that hold the insulation onto the firewall). Post what you find for comments.
  12. mgtstumpy
    mgtstumpy
    Just posted on another HAMB thread
  13. LOU WELLS
    LOU WELLS
    from IDAHO
    Some of the holes may be for the rubber insulator that was on the rear of the shakey Model B engine...
  14. The fire wall in post #12 looks pretty good, only a few incorrect holes. You need to remember that the same firewall was used for the 4 cylinder and the V8. The holes for the vibration damper on the Model B engine and a few more unique to the Model B were in all firewalls and were left open when a V8 engine was used. There are some extra holes unique to the V8 that were left open when a 4 cylinder was installed. The insulation pad on the inside of the firewall covered these holes.
    I think Terry needs to post a good clear photo of his firewall and ask which holes are incorrect. A pieces of tape with numbers would help.
    Charlie Stephens
  15. LOU WELLS
    LOU WELLS
    from IDAHO
    Charlie: Thanks for the clarification and were there changes thru the production year?
  16. According to "The 1932 Ford Book" from the Early Ford V8 Club there were 8 changes to the firewall. The good news is that they all functionally interchangeable across all of the p***enger and commercial vehicles produced throughout the year.
    Charlie Stephens
  17. hotroddon
    hotroddon
    So does Racecar - they are called Palindromes
  18. terry k
    terry k
    from toledo oh
    Found a load of photos on Google. I ordered a new insulated panel for inside the firewall. Thanks for all of the help !!!
  19. Lazy Jake
    Lazy Jake
    Who did you order the insulated panel from?
  20. Do you know about the special bolts for the insulation pads and the hat shaped washers for the ones that need to be removed (the throttle etc)?
    Charlie Stephens
  21. terry k
    terry k
    from toledo oh
  22. terry k
    terry k
    from toledo oh
    Charlie.... No I do not...
  23. Lazy Jake
    Lazy Jake
    Thanks.
    Dale
