Technical Stock model a drop help
Discussion in 'Traditional Hot Rods' started by Kdearing, Feb 16, 2014.
  1. Kdearing
    Kdearing
    from Arkansas
    What's the most that a stock model a rear suspension can be dropped. I don't want to have to cut the frame. Just get as much drop out of it with out cutting it up?
  2. Hitchhiker
    Hitchhiker
    This good enough?
  3. Kdearing
    Kdearing
    from Arkansas
    What's needed for this to be done? How much of a drop is it ?
  4. adavis
    adavis
    I didn't modify the frame at all on my '31. I used a "T" rear spring and had a new main leaf made. It's reversed eye and 3 inches shorter (eye to eye). Rides nice and eliminates almost all the gap between the fender and a 7.00x16 firestone.
  5. Hitchhiker
    Hitchhiker
    reverse eye model A spring. 6 leaves. 4 inch drop.
  6. Kdearing
    Kdearing
    from Arkansas
    Where can it be bought
  7. Hitchhiker
    Hitchhiker
    I bought my reverse main from modelasprings.com and built the pack myself. Be careful taking the spring apart. Its under tension. I suggest using a spring spreader to take it apart. Then installing the new main leaf by itself. And building the pack from there using all thread rod to center it and big c clamps to compress.
  8. Hotrodmyk
    Hotrodmyk
    It sounds like this might be a first time with an A spring.
    First of all, you need a good spring spreader. Do not try to jerry rig something, you can get seriously injured. Don't ever try just knocking the shackles loose. Some also recommend leaving it in the frame until all the tension is removed, then lowering it out. This will retain the leaves in case there is a broken leaf (shrapnel) or broken center bolt.
    Then follow Hitchhiker's instructions.
  9. brokenspoke
    brokenspoke
    With a reversed eye spring a spring spreader doesent work
  10. mike bowling
    mike bowling
    As advised, a model a rear spring will literally take your head off if it has the chance- mucho tension.I think I had to open mine 5" or so to get the shackles back in.( done with the rear end out and a well made (bought)spreader). The reverse eye thing is a good question; step up to the plate, you who have done such a thing, and impart your words of wisdom. SAFETY FIRST.Good luck. Mike
  11. Main leaf by itself first on the shackles.
    Then build the pack on it like hitchhiker said.
  12. Kdearing
    Kdearing
    from Arkansas
    How much would a reverse eye 5 leaf 38 in from eye drop it?
  13. Hitchhiker
    Hitchhiker
    the secret to life, the universe, and everything is 42
  14. listen to hitchhiker
    any lower and your radius rods will hit the frame
    i know for a fact
    tk
  15. adavis
    adavis
    I tried using the stock model A spring by removing leafs but it just wouldn't drop. I didn't spend the money or time on a reverse eye because it looked like the problem was length of spring (eyes would be hitting perches before it was low enough). I talked to Chris (from Spokane...search him here on the HAMB) about how he got his coupe so low and he said T spring. I got one but still the same problem with length. I had a local spring shop bend me a new reverse eye main leaf 3 inches shorter than the stock T spring and its dang near perfect. I still have clearance (never had the banjo hit the crossmember) and it rides real nice. I just used 5 of the original T leafs to complete the pack.
    Like everyone says.....be careful with that compressed spring when you take it apart. Its like a loaded gun. I used C clamps to hold mine together until the initial tension was off. And definitely install the main leaf on the shackles first and the build the pack from there.
    Sent from my SCH-I535 using H.A.M.B. mobile app
  16. easyrider47
    easyrider47
    I bought a new spring from Eaton Spring Co. It was about the same tension but dropped the car about 3" in front. All the brake stuff worked fine with it.
  17. ZZLEGEND
    ZZLEGEND
    Yes it does. ;)
  18. two coupes
    two coupes
    On my -31 coupe I used a Model A main leaf with reversed eyes from Vern Tardell ($110)+ 4 leafs, that dropped it 4", works fine, even with the kids in the rumble
  19. brokenspoke
    brokenspoke
    Proved me wrong....good idea
  20. ZZLEGEND
    ZZLEGEND
    Thanks. Here is a better shot.
  21. GCJones
    GCJones
    I got 3 1/2" drop from a Posies reversed eye and taking out two leaves[ the short ones].
  22. hotrodderhaag
    hotrodderhaag
    i never install a spring packed,
    i dismantle it, install the main leaf. install the remaining leaves then slide it up in the crossmember. much easiser and safer if doen right.
    i have had 2 purchases spring spreaders fly apart, so i built my own, but i still prefer to unpack them first.
  23. pasadenahotrod
    pasadenahotrod
    from Texas
    I always wrap the spring with chain before commencing any spreader operations to ***emble or dis***emble or install. Better safe than sorry, just one leaf spinning out can whack a knee, or other essential body part, to pieces.
