Will stock Mustang2 suspension fit under the stock front fenders on a 34 Plymouth. Also are the frame rails too wide? Anyone have closeup photos to share?
the track width of a MII is 56 and abit inches (hub to hub)... if you have stock MII stuff, get a welder series crossmember.. worth it then modifying a stock crossmember to fit your car.
http://www.jalopyjournal.com/forum/showthread.php?t=70073 Read the above link, please. This will hopefully answer everything you needed to know.
or make your own like ELpolacko posted above.. then its a true owner buiilt ... im just not handy enuff or proper tools so i bought a welder series
Stock MII crossmember is 23" between framerails, 27" including framerails, and 32" from top of shock to top of shock. The one I have in my back yard does not have spindles on it, so I don't know the hub-to-hub measurement. If you buy a Fatman crossmember (as I did for my '37 Plymouth), it will be the correct width, and you can still use the stock MII spindles, arms, etc. Fatman also has a bracket to mount a mid-70's GM disc brake caliper.
