straight axle angle ?
Discussion in 'The Hokey Ass Message Board' started by tobyflh, Mar 14, 2013.
  1. tobyflh
    tobyflh
    from Peru il
    if a 37 ford straight axle is angled 7 degrees back should I angle the spring the same? this is going to be a spring behind setup. I did a search but I know I didn't put in the right search words to find the answer.
  2. HOTRODPRIMER
    HOTRODPRIMER
    Are you planing to mount the spring to split bones?
    Usually you do have to mount your cross member with the degree you hope to achieve. HRP
  3. tobyflh
    tobyflh
    from Peru il
    yes, forgot that info
  4. tobyflh
    tobyflh
    from Peru il
    is 7 deg the right angle?
  5. Flat Roy
    Flat Roy
    7 deg, when every thing is put together, is right for modern day wide tires. Leave the spring alone.
  6. tobyflh
    tobyflh
    from Peru il
    spring is not mounted yet it is a custom frame
  7. tobyflh
    tobyflh
    from Peru il
  8. Flat Roy
    Flat Roy
    Be patient. Put every thing together. See what it looks like. If the caster ends up any where between 4 & 7 degrees wait to be able to take it for a spin to see how it handles, then go from there.
  9. And work out the difference between a straight axle and an I beam or original tube axle.
    Doc.
  10. tobyflh
    tobyflh
    from Peru il
    it is an I beam axle
  11. davidwilson
    davidwilson
    from Tennessee
    spring pad should be welded onto the frame with 7 degrees
  12. Nitro Breath
    Nitro Breath
    from Eugene, OR
    Yes, to avoid spring bind at the perches and shackles, the axle and the spring should be at the same angle. Spring-over or spring-behind, no difference.
  13. DICK SPADARO
    DICK SPADARO
    Your spring should be mounted so that its flat surface is parallel to the ground. The spring carries the weight of the vehicle. This weight of the vehicle is perpendicular to the ground. By using a swivel style perch mount you will be able to adjust the caster curve that you wish without effecting the spring bind or the spring shackle twist.
  14. tobyflh
    tobyflh
    from Peru il
    so that would be no angle on the spring?
