Straight Axle Caster Deg.
Discussion in 'The Hokey Ass Message Board' started by onebadrambler, Apr 8, 2011.
  1. onebadrambler
    onebadrambler
    What is an acceptable amount of pos. caster for a solid axle set up?I have 15 deg. now and the car has a severe wobble when hit a bump at speed.The factory spec. for the axle is 2-4 deg. pos[​IMG]
  2. Master of None
    Master of None
    I'm running 7 degrees on mine with no problems.
  3. Lucky3
    Lucky3
    No two are the same as it also has to do with the center of gravity of your car/engine. 8-10 for the street and 10-12 if you're racin an goin fast.
    You'll just have to try several settings.
