straight axle falcon help
Discussion in 'The Hokey Ass Message Board' started by fastphil, May 7, 2008.
  1. fastphil
    fastphil
    from lufkin tx.
    ok made up my mind. gonna go for it and build a g***er out of my 63 falcon. can anyone give me info on what to do with the steering. ie.use same sector?...change pitman arm?...cross steer? i have seen a few good pics,but can not tell exactly how they are put together.just do not want to make any mistakes.
  2. Autoslim
    Autoslim
    from texas
    I'm no expert by any means, but I am going through this right now with a 64 Comet. I think you'll find most do a cross steer with a fabbed arm on the p***enger side spindle. You can also do a cross steer and use a drag link attachment point. Speedway sells them... I think some folks have had bump steer issues with that set up, but search and you'll find plenty of discussions.
    I made my steering arm out of 3x3x1/2 inch angle and are using the top two spindle to backing plate mounts on a Econoline axle I narrowed.
    Search and you'll find plenty. Several guys around here offered good advice when I was starting my straight axle conversion. BTW...take your budget and double IT.
  3. chaddilac
    chaddilac
    pm G***erman, he's building a falcon G***er... he's had a couple of them.
  4. fastphil
    fastphil
    from lufkin tx.
  5. tpw35
    tpw35
    I am building a 65 falcon, I moved my steering box forward of the axle *(front steer) this seems like it will work out a little better.
  6. fastphil
    fastphil
    from lufkin tx.
    that's the same thing i was looking at.are you going to drop your pitman arm?
