straight axle falcon progress
Discussion in 'The Hokey Ass Message Board' started by fastphil, Jan 12, 2010.
  1. fastphil
    fastphil
    from lufkin tx.
    got a 31 plymouth axle,390 motor,headers off a truck turned upside down and cobbled into fender headers.rear 1/4's openings moved forward 2".working on the brakes now.welded brackets to the spindals that support double piston gm calipers.running new lines ect.
  2. 69fury
    69fury
    from Topeka
    Right on! You got your headers sorted quick and easy, it seems. My 61Falcon has a small block dodge popped back through the firewall 6 inches so i'm gonna have to have someone make a set of fenderwell headers from scratch (not my specialty).
    Early '63, right? How are you on radiator/fan room? The guys on the fordmuscle board swear by Maradyne fans for being the slimmest. Check the tech write ups about the comparison.
    Is that the stock steering box? cross steer still (I dont know if the plymouth axle is side or cross steer)
    I like that you took the plunge on moving the wheel openings forward.
    -rick
  3. fastphil
    fastphil
    from lufkin tx.
    got the radiator in last week.everything came out of a 69 galaxy.built some saddles for the rad to sit in. went with a flex fan with an 1.75" spacer.no room for clutch fan.used fan shroud and even the radiator hoses worked with a little t*******. the axle is cross steer now after i built a steering arm to mount up high on the p*** spindal.had to modify the pitman arm,but the drag link is level! i'll post more pics later.the wheel openings were a breeze.lot's of extra tire room in there.
  4. newfalconowner
    newfalconowner
    from NS Canada
    interesting headers, im looking for some for my build,, thanx for the tip :)
  5. fastphil
    fastphil
    from lufkin tx.
    headers were on a 66 ford pu. took the left side cut most the pipe away fliped them over and ran the tubes to the collector.other side took some imagination though.had to cut the flanges swap pipes and some weld on bends around the sector and presto headers! extended the collectors and added 2.5" pipe stubs for my exhaust to run through.gonna cap off the collector flange with a cap and br*** wingnuts.
  6. Looks like it's going to be a cool car! Interesting steering arm setup.
  7. what's that in the lower right corner of the last pic?
  8. newfalconowner
    newfalconowner
    from NS Canada
    thanx,, im building mine as a street car (hopefully) so i will need a full exhaust.
  9. fastphil
    fastphil
    from lufkin tx.
    it's a sportster with a girder front...on the jockey journal if you want to see it
  10. fastphil
    fastphil
    from lufkin tx.
    yea mine is going to be on the street and track.had a full time race car i sold it last year.i miss going to the car shows and meets.
  11. newfalconowner
    newfalconowner
    from NS Canada
    cool,, like to see the finished product when done.. i still need to find cheap flanges andsome headers to make something work for me.
    rick
  12. fastphil
    fastphil
    from lufkin tx.
    yea cheap is my middle name.bought that 66 had a 390 and c-6 with the headers.pulled all that out and sold the body for $100 more than i had in it.almost the same with galaxy my motor came out of.filled it full of s**** iron and hauled it off and made $75 on that deal.a freind gave me the sanderson collectors.i even did some work on a guys truck and he gave me this body with a new windsheild. think i'm into this ride for about $300 like it sets. damn i'm cheap!
  13. newfalconowner
    newfalconowner
    from NS Canada
    lol cool... its thrifty, not cheap (as my wife says,lol)...
    no one in my neck of the woods has 390 headers cheap (errr.. thrifty) or free,lol... so the floor/firewall waits)..
  14. Gasser1961
    Gasser1961
