Straight Axle Holes?
Discussion in 'The Hokey Ass Message Board' started by Hard On Parts, Jun 21, 2004.
  1. Hard On Parts
    Hard On Parts
    from SE Kansas
    What do you use to put the holes in straight axles? Plasma(do not have one), torch, Big *** drill bit, 12 gauge shotgun with slugs [​IMG]?
  2. FoMoCo_MoFo
    FoMoCo_MoFo
    you can do it with a big-*** drill 7/8" or 1" and a big-*** drill press, but they come out much nicer with a mill. do you got any machinest buddy's? that's who I mooch off of for **** like this.
  3. Drill em half way through on the press then flip the axle over and use the pilot hole to index it. Use lots of lube.
  4. pikesan99
    pikesan99
    I had a guy do my axle on a mill. He did big in the middle out to smaller on the ends. Looks sweet. It would take a big drill press!
  5. Hard On Parts
    Hard On Parts
    from SE Kansas
    [ QUOTE ]
    [/ QUOTE ]
    You gotta pic?
  6. Unkl Ian
    Unkl Ian
  7. Deyomatic
    Deyomatic
    from CT
    Ian, would that be a special hole saw, or just a regular old metal hole saw?
  8. Didn't Roothawg or someone do a post about using a hole saw? It was a long time ago, but whoever it was just used a regular ol' hole saw and a hand held drill too, I think.
  9. Unkl Ian
    Unkl Ian
    A regular hole saw will work.
    Just run it slow,and use lots of coolant.
    Of course,a Carbide tipped hole saw would last longer.
