Customs Straight axle question
Discussion in 'The Hokey Ass Message Board' started by oldsvroom, Jul 31, 2022.
  1. oldsvroom
    oldsvroom
    I recently built a wild custom and am now experiencing death wobble on occasion. I have a model A 4” drop axle with traditional steering. I have noticed my axle isn’t straight up and down would this cause the issue ? Do I need a pan hard bar in the front?
  2. Andy
    Andy
    Pics would help
  3. squirrel
    how straight up and down the axle is, is related to how much caster you have...you want the top leaned back, perhaps 7 degrees.
    Steering linkage looseness is one factor that can cause shimmy, but there are many others. Like he said, pictures will tell us a lot, and help us help you figure it out.
    jimmy six, Deuces and anthony myrick like this.
  4. gimpyshotrods
    gimpyshotrods
    Which tradition?
    Side-steer and cross-steer are both traditional.
  5. oldsvroom
    oldsvroom
    Reverse corvair steering box
  6. oldsvroom
    oldsvroom
    I’m not home now I will put up picks tomorrow
  7. Andy
    Andy
    A Corvair box is easily overloaded.
  8. I agree but it depends on what it's in. He hasn't told us what kind of vehicle he built. Could be a T-Bucket then it's probably okay.
  9. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    And don't overlook tires.
    Bandit Billy likes this.
  10. Kevin Ardinger
    Kevin Ardinger
    Lots of caster and a panhard bar.
  11. AVater
    AVater
    Check toe and tire inflation as well.
  12. gimpyshotrods
    gimpyshotrods
    Looks like too much toe-in.
  13. squirrel
    loads of tire offset from the kinpin, too
    gimpyshotrods and Pist-n-Broke like this.
  14. To much wheel offset as Squirrel pointed out will add to it every time. That also put's a big load on the Tie rod and the faster you try to go the more the load grows. Add in the position your front shocks are mounted and you might as well leave them off. Yep, you have a shaker.
  15. dana barlow
    dana barlow
    from Miami Fla.
    Nice done body,I like it,though I may of done grill shell n windsheild in another way may self ;)[ our art eye maybe close!!]
    . High five on that custom design work.:cool:
    Your front shocks are too close together at the bottom of axle, there mounts as is,not enough movement ether up n down. A panhard bar* would help a lot on front axle to frame/if you don't have one now?.
    The front tires are a bit heavy,being as wide as they are. About 1 or 2in. less tread/wide gets better to control.
    I can't tell with those photos,but there maybe too much front scub?{ if rim n hub,is mounting tire too far outside of kingpin?
    If all the other things;like balance,round n true, and castor n camber/tow are right,with no sloopy gaps have been address.:D
  16. oldsvroom
    oldsvroom
    I have raised the front up more since the picture was taken thinking it was wheel hop but that wasn’t it.
    dana barlow likes this.
  17. oldsvroom
    oldsvroom
    I’m not real happy with how the windshield came out either but I was up against a time deadline.
  18. gimpyshotrods
    gimpyshotrods
    Take your lower shock mounts off and swap sides, putting the lower ends farther apart.
    dana barlow and Pist-n-Broke like this.
  19. I’d say some reading up on front end geometry and setup would help you greatly.
    Pist-n-Broke likes this.
  20. 52HardTop
    52HardTop
    I bet his axle should have about the same amount of caster as his radiator? If the axle doesn't mimic the angle of that shell, is it not enough.
  21. oldsvroom
    oldsvroom
    First 120 miles no problems . Thankfully it’s only been at lower speeds . The car drives great at 60.
  22. gimpyshotrods
    gimpyshotrods
    Also, inspect for any evidence that the shackles are hitting the frame on compression.
    They look awfully close.
    Notch the frame as necessary.
  23. gimpyshotrods
    gimpyshotrods
    Nope.
    On a stock Model A crossmember, the pads for the radiator mounts are flat level. The spring cross member is not.
    The spring crossmember is tilted back to match the arc created by the front wishbone, so torsional twist to the main leaf is kept to a minimum on cycling.
    It does not, and should not match the caster angle. Those two angles have nothing to do with each other.
    One is the kingpin angle, when observed from the side, in relation to level ground.
    The other is relational to the length of the wishbone, when observed from the side, offset to the point of shackle attachment, and taken as an average over expected normal suspension cycling.
    If it happens to compute to the same angle as caster, it is pure coincidence, and bears not relationship to the radiator angle.
    Andy likes this.
  24. gimpyshotrods
    gimpyshotrods
    Caster, per Ford, is to be set at 7º, with the vehicle loaded.
    That radiator shell is over 15º.
    On an a Model A, it would be vertical.
    Andy likes this.
  25. oldsvroom
    oldsvroom
    Ok here are the pictures of the front end parts
  26. gimpyshotrods
    gimpyshotrods
    Check every single point of movement for play.
    Boneyard51 likes this.
  27. 1971BB427
    1971BB427
    from Oregon
    Might be an illusion, but pictures look like both front tires are leaning out pretty significantly? Too much negative camber? If so that could easily cause the death wobble. Have you measured side to side at 6 o'clock and 12 o'clock to make sure the axle isn't bent and causing the tires to be out at the top?
    Other things to check are:
    Toe in, need about 1/8"-1/4" max.
    Worn parts, like kingpins, tie rod ends, etc.
    Steering drag link ends.
    Wishbone ends.
    And of course the previously mentioned @ 7 degrees kingpin angle.
  28. oldsvroom
    oldsvroom
    All parts are brand new so nothing (should ) be bent but who knows.
  29. I think what's being referred to here is the vertical line of the tread grove here to the edge of the photo.
    [​IMG] [​IMG]
    If this is a true line from true vertical to the world you have a real problem. It may well just be camara angle. If this is an issue that truly exists only an alignment shop can correct it, but not all shops can.
    Google what is camber angle and watch a video. Easiest way to explain it.
    1971BB427 likes this.
  30. 1971BB427
    1971BB427
    from Oregon
    Yep! That's exactly what my question was. From all appearances it seems to be really out of whack.
