Technical straight eight camshaft
Discussion in 'The Hokey Ass Message Board' started by okeesignguy, Mar 2, 2018.
  1. okeesignguy
    okeesignguy
    What is the approximate length of a straight eight camshaft...?
  2. Clay Belt
    Clay Belt
    What engine is it for?
  3. Hnstray
    Hnstray
    from Quincy, IL
    for common American straight 8's...approximately 31" to 36"...plus or minus an inch or two. For example, a Buick 248/263 cu in is 4" shorter than the 320 cu in. version. Later today I can post the length of the shorter version as I have a bare one in my shop.
    Ray
  4. okeesignguy
    okeesignguy
    LOL Perhaps I shoulda specified...
    I want to use one as a rear bumper on my coupe...
    I have one from a SBC I am going to use as my front spreader bar...
    So...I guess my next question is where might I find a junk one...???
    Thanx guys!
  5. RichFox
    RichFox
    Might be easier to find a cam from a large six cylinder diesel engine. Pretty long and maybe steel.
  6. okeesignguy
    okeesignguy
    Like from a semi...?
    You say it may be steel...are the straight eight cams not steel...?
    This might be better because I live in a small country town in the middle of nowhere but there are lots of semi guys...
    Thanx!
  7. Atwater Mike
    Atwater Mike
    That's NOT why they call it a 'bumpstick'! :D
    When I was an apprentice, I had to pull one out of a Pontiac flathead eight. After removing side pans and compressing 16 (!) valve springs and magnetically 'reclaiming' keepers and retainers, (a stretch from outside brake drum) I raised valves and lifted tappets then stood (ahhh, relief!) and strode up to the front, and pulled on the cam...
    Little bit at a time, 'clunking its way out', turning and lifting, went on for three feet!
    Damned thing was longer than a story...
    302GMC, czuch, pat59 and 1 other person like this.
  8. okeesignguy
    okeesignguy
    I did not think those sixes were very long...that's why I was thinkin straight eight...
  9. RichFox
    RichFox
    Roller cams are usually steel. Flat tappet cams are often cast iron. But some are steel.
  10. FrozenMerc
    FrozenMerc
    Have you ever stood next to a 60 Series Detroit? A fair bit longer then an automotive straight 8. They come in 677, 775, and 845 ci displacements and are about 57 inches long. The cam will likely be around 4ft long. Go to your local heavy truck repair shop. They likely will have an old core that they would be willing to sell you.
    Here is an internet picture of one.
    okeesignguy likes this.
  11. vickckik
    vickckik
    weld a couple of cams together for the length you want.
  12. okeesignguy
    okeesignguy
    That's an idea....I'll bet the DD cam would be fatter tho...???
  13. 'Mo
    'Mo
    This one is from a 425 Cat.
  14. okeesignguy
    okeesignguy
    That looks awesome :)
    czuch likes this.
  15. ROADSTER1927
    ROADSTER1927
    Sorry it is personal taste, but it says R-- Rod to me.
  16. okeesignguy
    okeesignguy
    You're right...
    Too bad we arn't all like you and our cars all like yours...
    Thanx for your "input"
