straight six engine identification help
Discussion in 'The Hokey Ass Message Board' started by the pinstriper, Jun 28, 2011.
  1. the pinstriper
    the pinstriper
    from duxford UK
    hey guys, im from the uk and need to fill out a fair amount of paper work to get my 59 apache registered. im having trouble finding the correct info to find what model my engine is, i believe its a 235.
    ive done a search and read on the codes etc but nothing seems to match what ive got.
    this is the engine code off of the machine plate on the engine b3525r
    then from behind the starter motor i found c0114 j247
    and on teh head b5784b850
    any help would be great.
    cheers in advance guys. joe :confused:
  2. OldBuzzard
    OldBuzzard
    The numbers you show don't make much sense except for the J247 which looks like a date code for Oct 24 1957 if it is a 235.
    What do you mean by machine plate? There should be a machined surface just behind the distributor with some letters and numbers. It is usually longer than what you show from the "machine plate."
    I don't know if the block casting numbers moved after 1955 but before that they were between the pan flange and the cast ridge just above the flange up front between the fuel pump and the plate sticking out that holds the timing gear cover. Unless you have washed the engine you will need a wire brush to get the grease off. The numbers will be smaller than most casting numbers.
  3. squirrel
    Can you post pictures of the numbers? The stamped numbers near the base of the distributor would tell what the engine was installed in originally, but we'd expect it to be something like F1026A the numbers you listed don't look right.
    The casting date J 24 7 on the block is helpful...see if you can find a similar number sequence on the head, probably under the valve cover.
  4. LowKat
    LowKat
    if it has a 'machine plate' rivited to the engine it was remanufactured.
  5. the pinstriper
    the pinstriper
    from duxford UK
    theres a section on the block thats a plat serface, which i take was machined flat from factory and has numbers stamped init. i will check again when i get home and post photos. thanks for your help.
    will try and get some decent photos when i get home mate, i didnt think the numbers look right from what i found on the engine and see on the threads on here.
    cheesr for your help
  6. OldBuzzard
    OldBuzzard
    Where??? is this flat surface???
  7. squirrel
    I think he's referring to the machined surface at the base of the distributor, where the engine number is stamped. There are different meanings for the word "flat" and there's an ocean between us and the engine....
  8. the pinstriper
    the pinstriper
    from duxford UK
    sorry for the lack of correct terms guys.
    heres some pics, one of my engine incase there is any obvious ways to tell what it is.
    heres the picture of the surface with the engine number?
  9. squirrel
    That number pad has been ground and restamped, which is why the numbers don't make sense.
    Looks like it's probably a 58 truck engine, or a 58 car engine, depending on whether or not it has the 3 mounting bosses on each side of the block. Cars used them, trucks did not. Also cars had hydraulic lifters, trucks had solid.
    You could probably get away with saying it's the original engine, I really doubt the inspectors could tell, either way.
  10. the pinstriper
    the pinstriper
    from duxford UK
    so its not the original engine then?
    what are the mounting bosses you speek of?
  11. squirrel
    These three (they would be on both sides of the engine block). They sometimes had them on truck engines, usually not.
  12. Mr48chev
  13. Dago Red
    Dago Red
    from Delaware
  14. the pinstriper
    the pinstriper
    from duxford UK
    thankyou, will go took later and see. youve been very helpful mate thankyou very much
    thanks for the links mate. will sit and have a look and see what i can match up later. wont be an issue at all would just be nice to see what ive got.
    ah didnt no anything about this will go look for these!
  15. the pinstriper
    the pinstriper
    from duxford UK
    just looked, mine has the bosses, couldnt mind the captain bars though
  16. 54metalman
    54metalman
    Its a 235 in the pics. Full oil pressure system. Fits 54 thru 62 car and truck. Good motors. Just a question. Why is everyone so hung up on numbers? I thought that was for the muscle car resto nuts. Just checking. Sorry if I offend anyone.
  17. the pinstriper
    the pinstriper
    from duxford UK
    thanks for definatly confurming. in the uk we have strange regulations on imported vehicles and lots of paper work when we have to "register" a car. so i had to identify what i have, engine number, dates etc.
  18. OldBuzzard
    OldBuzzard
    The numbers only tell you what it is, that's all. How do you know the picture is not a 261??
