Projects Strange Days Bellytank. No more little screws.
Discussion in 'The Hokey Ass Message Board' started by Chaz, Jul 13, 2008.
  1. Chaz
    Chaz
    Today was the first day in months that we weren't working on attaching panels and tapping little screw holes. It felt great to get back to the big stuff. Our first order of business was to figgure out a path for the steering.
    We started by attaching the ****tershield and valve covers to the dummy engine so that we knew how big everything would be on final ***embly.
    When we figgured out the placement of the wheel in the ****pit, the steering shaft will have to p*** between the left valve cover and the intake. The steering reverser will fit on the drivers side of the firewall to provide clearance for the steering joints and to keep their angles to a minimum. We drilled the firewall.
    The steering reverser was drilled and tapped to attach to the brackets.
    The angle iron brackets were drilled to attach to the reverser and the firewall
    The reverser was installed. Here's a photo of it protruding through the firewall. The br*** tube in the pic is just a piece we used to determine shaft lengths.
    Then I came home and ordered a bunch of steering joints, flange bearings, and steering wheel quick disconnects. ****! that stuff is expensive.!!!!
  2. Toymont
    Toymont
    from Montana
    Looks good guys, sorry I missed it.
  3. ChevyGirlRox
    ChevyGirlRox
    from Ohio
    Looks like things are coming right along! Keep up the good work!
    Thanks for posting the progress.
  4. bct
    bct
    cool beans....looks like you are doing it up right...
