Technical Strange flathead issue
Discussion in 'The Hokey Ass Message Board' started by olscrounger, Dec 13, 2018.
  1. olscrounger
    olscrounger
    A local guy here bought a 39 woody project that had a supposedly fresh flathead (37) with a 39 box and fresh brakes etc. He was dumping all the running gear and a friend of mine bought the engine and trans. He took it home and they put it on a engine running stand. They pulled the plugs and put a bit of oil in the cylinders and spun it over by hand-all good and added fresh motor oil. They fired it and it lit right up-no problem and ran good but then made a squealing sound so they shut it off. Checked everything they could and fired it again-ran good for a bit then squealed again-oil pressure was pegged. They shut it off and tried another gauge-near 100lbs! they said. They are 200 miles from here. His friend who is helping him has built numerous flatheads but is baffled by this. I told him stop and pull the pan etc to see what's up-any suggestions? I haven't fooled with a flathead since the early 60's. Oil pump gear? what else? I'm far away. He now is gonna p*** on the rearend and the whole front end which is being s****ped as well.
  2. Ghector23
    Ghector23
    Sounds like not enough bearing clearance. As motor runs it heats up and expands. Crank expands into the bearing causing squealing sound. Shutting it down allows it to contract, restoring clearance. Pull crankshaft and check bearings for damage.
    Ghector23
    tubman and olscrounger like this.
  3. flatjack
    flatjack
    It may have been drilled for that 90% oil filtration. Has another hole been drilled and tapped on top of the bellhousing? If so. the cross p***age at the rear gets blocked. He would only get oil going to the rear main. May explain the high oil pressure reading.
  4. Bandit Billy
    Bandit Billy
    That's what happens when you plug up all the oil leaks! They need to breathe!
    Texas Webb likes this.
  5. alchemy
    alchemy
    And now they are just throwing the suspension away? Idiotic.
    olscrounger likes this.
  6. Kiwi 4d
    Kiwi 4d
    For the pressure to peg right out , it could be a stuck relief valve in the oil pump. But i dont think that explains the squealing.
    If as Flat Jack says the oil line at the rear are plugged or installed incorrectly it could explain the squealing as the bearings complain.
  7. GuyW
    GuyW
    Maybe pistons too tight in cylinder. Had that same result on an OT flathead Indian mc.
  8. olscrounger
    olscrounger
    will tell them--yep getting rid of front and rearend-both 39 complete with new brakes orig wide lug hubs etc.-I may try to snag them but really don't need them right now
    lothiandon1940 likes this.
  9. BJR
    BJR
    Buy them and sell them here for a fare profit. Someone here needs them.
  10. Nailhead Jason
    Nailhead Jason
    if you weren't in California, I would have already PMed you to find out where I need to go to get the suspension stuff. But I only do runs like that when they are under 900 miles.... Just cant under stand why people s**** this stuff, when it is still good!
    lothiandon1940 and sidevalve8ba like this.
  11. tubman
    tubman
    I heard that "squeal" several times in the past. Both times it was caused by oil starvation. Do your buddies a favor and tell them to not to run the engine again until they tear it down and find the problem. If they are really lucky, they may be able to save some of the components. Most likely, They'll find a bunch of "blue metal" when they take it apart.
  12. olscrounger
    olscrounger
    maybe found a home for the other parts-a fellow I know has interest
