Technical Strange plug GM steering column
Discussion in 'The Hokey Ass Message Board' started by djweaz, Aug 9, 2023.
  1. djweaz
    djweaz
    from Tennessee
    Switching out the steering column in my 40 Ford going to a floor shift setup. Picked up an old 70s column (Impala, Malibu, Camaro idk) It has a strange plug I’m not familiar with. The wires seem to be brown black and blue and they are flat with this plug. It’s not a fancy column with all of the bells and whistles just a plain old GM steering column. Anybody have a clue as to what it is? IMG_9202.jpeg IMG_9201.jpeg IMG_9200.jpeg
  2. David Gersic
    David Gersic
    from DeKalb, IL
    Doesn’t look GM. Where does the other end go to?
  3. MAD MIKE
    MAD MIKE
    That is for Cruise Control.
    Check the end of your left side stalk, the tip will be a push ****on. This was before the 80's multifunction switch. Usually an rocker switch on the dash to turn on cruise then set it by depressing the ****on on the stalk.
    egads, David Gersic and djweaz like this.
  4. 325w
    325w
    That’s it.
    djweaz likes this.
  5. Mr48chev
    That's the nice "older" column rather than the ugly later one that had the dimmer switch on the side of the column.
    djweaz likes this.
  6. djweaz
    djweaz
    from Tennessee
    you guys got it. Its cruise control I checked the left stalk, there is a ****on, I wont be using it any way I dont think my tri-power will like it very well plus I have a nice set from my other column which are going on it. Thanks guys
  7. 05snopro440
    05snopro440
    I don't see why your tri-power wouldn't like cruise. It hooks to the same spot a throttle cable does (if you go with a Rostra).
    djweaz and egads like this.
  8. djweaz
    djweaz
    from Tennessee
    Hmm I will have to look into that
  9. MAD MIKE
    MAD MIKE
    Can always wire up the switch to be used for something other than cruise. It's just a switch. Although I forget if it was momentary or not.
    djweaz and Budget36 like this.
  10. Bandit Billy
    Bandit Billy
    I was going to say eel, but I think I will go with cruise control as well.
  11. 283john
    283john
    That looks identical to the steering wheel in my dad's '76 Nova Concourse in case that info ever becomes helpful to you.
    djweaz likes this.
  12. No reason not to have cruise control with a tri-power. The six pac on my Galaxie loves cruise control. I have it set up so it won't hold speeds above where the secondaries start to open so about 78 miles an hour is as fast as I can run with the cruise on. Helps to keep me out of trouble.
    djweaz and vtx1800 like this.
  13. vtx1800
    vtx1800
    twenty years ago you could go to the local You Pull It yard and find all the stock parts to put together that cruise control system (which I did for a C10 pickup) ...........That was then....I was in the same yard a few days ago...nothing remotely that old:(
    djweaz and 427 sleeper like this.
  14. Fat47
    Fat47
    I use to go to the wrecking yard for most of my build parts. Used several of those columns over the years but never hooked up the cruise control. Like vtx said "nothing remotely that old" anymore. I'm even having trouble finding parts 10 years or older at the parts stores. djw was lucky to have come across that column.
    djweaz likes this.
  15. Some aftermarket cruise controls, can be operated by factory switches. Check out the instruction book for your cruise, you might get lucky.
    djweaz likes this.
  16. goldmountain
    goldmountain
    My '68 Pontiac Grande Parisienne had that cruise control. I really miss that car but can't remember what I did with it.
    djweaz and BJR like this.
  17. BJR
    BJR
    Look behind your garage, or under your work bench! :p
    djweaz and i7083 like this.
  18. djweaz
    djweaz
    from Tennessee
    I got mine at a Swap meet/car show a few years ago. We had a junk yard with a cl***ics section until a couple of years ago. I used to go sit there all fay and pull parts for future projects. Sadly the cl***ics section is gone
