Technical Strangled 350
Discussion in 'The Hokey Ass Message Board' started by Major76, Aug 9, 2024.
  1. Major76
    Major76
    Driving home the engine started to sputter out. Limped home. Engine is an older 350, no work done to it.
    when it runs now, sounds like a V6, instead of a healthy V8. Changed the fuel pump, spark plugs are good and getting spark, compression test is good and even across the board. At a loss now for what it could be.
    Tow Truck Tom and chryslerfan55 like this.
  2. gimpyshotrods
    gimpyshotrods
    Fire it up in the dark and look for spark plug wire arcing.
  3. henry29
    henry29
    or check for dirt/ debris in the fuel line
    Algoma56, hrm2k and chryslerfan55 like this.
  4. Black Panther
    Black Panther
    from SoCal
    Spark plug wires?..they fail under load and will show normal spark when testing without one.
    rod1 and chryslerfan55 like this.
  5. RMcCulley
    RMcCulley
    Check the distributor rotor & cap?
    Have another coil to try?
    Do you have a fuel pressure gauge?
  6. 19Eddy30
    19Eddy30
    from VA
    All above ,
    Check timing to see if it moved ,
    10-12 deg initial at idle ,
    Timing Chain ,,,
    HEI will burn hole in Rotor ****on & cap to coil ark,
    pole to pole ark inside cap ,
    VANDENPLAS likes this.
  7. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    You need to know if the trouble is one cylinder or they are all suffering.
    Older Chevys can sometime lose a cylinder from rocker failure.
    2FORCEFULL likes this.
  8. Not giving us a lot to work with...so most responses are going to be guesses...my guess is ignition related.
  9. Mr48chev
    Right now, this is the best answer of the 7 posts you got. Several of the others are good simply because they suggest the normal list of trouble shooting things one does when suddenly a rig doesn't run right.
    First did you change anything including buying gas not long before this happened?
    Second if it happens to be an OT engine donor type rig per HAMB thinking did you maybe go through a big puddle not long before it happened? What does the exhaust sound like now?
    I'd change the fuel filter simply because that is maintenance and they do clog up if you get some dirty gas and often clog up on a just got together and drove it rig with an old tank.
    If it has HEI along with what was said about checking cap and rotor look real close at the wires on the pickup coil. They are prone to breaking after flexing back and forth over the years. I have a rig that I should be looking at right now on rather than sitting here.
    While you have the cap off check for slop in the timing chain as it may have jumped time do to a worn out chain or plastic timing gear.
    DO NOT change more than one thing at a time if you are one of the guys who tests by swapping parts.
  10. ClayMart
    ClayMart
    Any other new noises since the problems began? Knocking, ticking, backfiring thru the intake or exhaust? Normal oil level and pressure, fresh clean oil, engine running at normal temperatures? As mentioned already, valve train problems would be worth looking into. Timing gear and chain, worn camshaft, sticking lifters, bent push rod, broken rocker arms, weak or broken valve springs, loose rocker adjustment nuts, rocker studs pulling out of heads, etc.
    Tow Truck Tom and Just Gary like this.
  11. Just Gary
    Just Gary
    Welcome to the HAMB.
    fastcar1953, Budget36 and Sharpone like this.
  12. A bad condenser can give similar symptoms as a carb with **** in it. JW
    Tow Truck Tom likes this.
  13. oldolds
    oldolds
    Someone put a potato in your exhaust?
    67drake, Tow Truck Tom and 2Blue2 like this.
  14. tractorguy
    tractorguy
    Not sure what your 350 is installed in, but in the old days, stock exhaust systems from GM were "double wall" pipe. Inner pipe would get too hot and collapse or curl up restricting exhaust flow.....outside of pipe still looked perfectly round.
  15. F-ONE
    F-ONE
    from Alabama
    Diagnostic....
    While the engine is running, pull one plug wire off, listen and put it back on.
    The engine should stumble when the wire is removed.
    If there is no change, you have found the offending cylinder or cylinders.
    They make insulated plug wire pullers to prevent shock.
    High mileage GM engines can “pull studs”. The rocker stud can start coming up. This may or may not show with a compression check.
    A dirty check is to pull the valve cover and lay a straight edge over the rockers. If any are excessively high that may be the culprit.
    2FORCEFULL, Sharpone and tractorguy like this.
  16. bobss396
    bobss396
    A vacuum gauge will show up a clogged exhaust really fast. Most I have seen will make a loud "hiss" out the tail pipe. If you have 2, see if one side is worse than the other.
    When I was fixing cars around 1978, we would get new-ish GM cars in with the separated exhaust.
    tractorguy likes this.
  17. ALLDONE
    ALLDONE
    thanks, saved me some typing, but like you said, I would start with pullin one plug wire at a time.. could also be a plug that bridged over the ground strap
    F-ONE likes this.
