Technical Stripped Threads
Discussion in 'The Hokey Ass Message Board' started by Truck64, May 10, 2018.
  1. Truck64
    Truck64
    from Ioway
    So the block to firewall ground point, at the firewall the 1/2" bolt keeps loosening up just enough to be annoying.
    Have a set of taps, ran one through, congratulated myself and that ... didn't seem to help too much. I think it was a taper or plug tap? Is that the wrong type? Just too worn?
    So maybe the answer is to step up one whole size, if there's enough meat in the firewall side of things? Thing is don't want to make a career out of it or, ****** it up. Maybe an oversize self-tapping bolt? Just need the bolt to get tight and make a solid electrical connection. Amazing how the stupid stuff can kick my *** sometimes.
  2. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Lock washer? Lock***e?
    Truck64 likes this.
  3. David Gersic
    David Gersic
    from DeKalb, IL
    egads, Truck64 and Terrible80 like this.
  4. Bandit Billy
    Bandit Billy
    If you only have one side access, nut zert it.
    Truck64 likes this.
  5. LM14
    LM14
    from Iowa
    Consider a stud in the hold and using a nut on the outside.
    SPark
    Truck64 likes this.
  6. Fordors
    Fordors
    Sounds as though you are referring to a self tapping screw with a 1/2” hex on it. The hole must be worn oversized and no tap will help you, the firewall is likely not thick enough to use a tap anyway. Just redrill a new hole of the proper size next to the first one.
    Truck64 likes this.
  7. 57 HEAP
    57 HEAP
    If the bolt is attached to sheet metal and not a threaded "nut", then place a paper clip in the hole and if you can, bend it against the firewall on both sides. This will close up the hole enough that the ground bolt will tighten.
    If there is a machine thread "nut" attached to the firewall that the bolt goes into, try putting dimples in the bolt with a center punch. This will cause the threads to become distorted and grab each other once again.
    Also, if there is a nut on the firewall, perhaps you could weld a stud to the nut so it won't back off. Then a nut to hold the cable in place.
    Truck64 likes this.
  8. Truck64
    Truck64
    from Ioway
    Thought of that, except access is tight. A longer bolt & and nut is probably the easiest and best solution.
  9. Truck64
    Truck64
    from Ioway
    We used to put steel wool around wood screws iirc, heard about disfiguring threads with a hacksaw etc. My luck I'd just have a real mess and still wouldn't work.
  10. Unkl Ian
    Unkl Ian
    Ground at a different spot.
    Hnstray, Truck64 and Terrible80 like this.
  11. If it's a 1/2" bolt like you said, it takes a 3/4 " wrench.
    If it's a bolt that takes a 1/2" wrench then it's a 5/16 bolt.
    The firewall does not have enough meat to hold the threads for either one of those bolts.
    You need a helper, a bolt and 2 nuts.
    Shove the bolt thru the firewall from the inside and put a nut on it, tighten it down well onto shiney metal. Put your ground on the bolt and put the other nut on it.
    Hnstray, David Gersic and Truck64 like this.
