stripping be gone
Discussion in 'The Hokey Ass Message Board' started by harpboys4, Sep 24, 2008.
  1. harpboys4
    harpboys4
    from So Cal
    I am hoping somebody has a good idea on how to remove pin stripping with out damaging the paint.I also need to remove a decal from the trunk.I do not want any left overs from the guy I bought the car from.He painted a name for the car on the trunk like it was some kinda a freakin jet boat.The rest of the stripping looks good and the paint is nice. Thanks for any help you can come up with
  2. Unkl Ian
    Unkl Ian
    Easy Off oven cleaner,the stuff in the Yellow can.
    Might take more than one application.
    Test in an incon****uous spot first.
  3. hugh m
    hugh m
    from ct.
    An old timer bought a stock car I had lettered up with One Shot .Was surprised I didn't know about using Easy Off Oven Cleaner to remove the numbers.I'd try it on an incon****uous spot first though.Good luck.
  4. KreaturesCCaustin
    KreaturesCCaustin
    from Austin, TX
    I'm a pinstriper and I've used Easy Off. It works great. Get the original stuff, not the low odor kind. Not that it's fail safe, but I haven't damaged a good paint job yet. Spray it on, leave it about 5-10 minutes and start wiping it off with a soft cloth or Viva paper towels. Sometimes it'll leave a few flakes of the striping on there and you'll have to do it again. Just clean it up with windex. You may need to buff a little if it slightly dulls the finish, but I haven't had to yet. I did the fender and tank of my Kawasaki Vulcan that way and didn't lose one bit of gloss. Works like a champ.
  5. Spaulding
    Spaulding
    from Wichita
    As for the decal on the trunk, apply a little heat to it with a hair dryer or heat gun. If there's adhesive leftover try a little lighter fluid.
  6. BigNick1959
    BigNick1959
    Use the original formula Easy Off, the pretty smelling stuff wont work as good.
  7. hrm2k
    hrm2k
    try a little bit of " goof off " on the decal. You can find it at the hardware type stores.
  8. Rozzi
    Rozzi
    The prior owner of my coupe striped the indented lines on both the front and rear bumper. (see pict) Do you guys have any experience using Easy Off on chrome? Will it damage it? I would like the striping gone.
  9. 29 sedanman
    29 sedanman
    from Indy
    On Chrome you can get away with Laquer thinner.
  10. jamesdfo
    jamesdfo
    Provided the paint is at least six month old, and was 2K (ie: catylized), easy off, or enamel reducer on a lithowipe will work. For decals, tape stripes,etc, the best results are by using a kettle of hot water poured onto the panel. pour some water, get an edge lifted with your fingernail, more water, peel, repeat......I typically have the decals, signs come up with 95% of the adhesive still on them, leaving very little cleanup. And for removing the remaiing adhesive, final wash solvent is strong enough to soften the adhesive without being harmfull to the paint. (and again, the age & 2K rules apply with the wash solvent)
    HTH
    James
  11. FoMoCoPower
    FoMoCoPower
    Graffitti Remover
  12. Unkl Ian
    Unkl Ian
    Heat will soften the adhesive on vinyl decals.
    Makes them easier to remove.
  13. Damn, I thought this was a thread about getting rid of strippers.......those hussies are always prying money from my hands! Although, I reckon if I sprayed them with Easy Off that'd work too!
  14. Rozzi
    Rozzi
    Thanks for the tip. I picked up some today and so far it is taking off the stripes no problem.
  15. harpboys4
    harpboys4
    from So Cal
    I am going to try this out on Friday.Thanks to all for the tips.I will post a before and after pic so people can see visual proof.
  16. harpboys4
    harpboys4
    from So Cal
    I went to all the local markets and could not find any original Easy off.I am going to go into the low rent district and see if I can find a can.
