Stripping color from A N fittings
Discussion in 'The Hokey Ass Message Board' started by firingorder1, Feb 22, 2010.
  1. firingorder1
    firingorder1
    I was on a motorcycle forum and the question was asked can the color be stripped from an A N fitting? I am a long way behind the times so A N fittings are still exotica to me. Can the color be stripped from these fittings?
  2. Da Tinman
    Da Tinman
    yeah. stick them in a freezer bag full of easy off evne cleaner and set them in the sun for a few hours, anodizing should brush off.
  3. Blue One
    Blue One
    from Alberta
    The color would be next to impossible to strip without ruining the fitting. The color is anodizing, a chemical enhancement of the natural oxide layer on the aluminum. It's done somewhat similar to electroplating.
    Far easier to buy plain un- anodized fittings, or clear (no color) anodized.
  4. heatmiser
    heatmiser
    from mia
    x2 on the easy off
  5. Da Tinman
    Da Tinman
    easy off even cleaner removes anodizing without harming the fittings in anyway
  6. bobkatrods
    bobkatrods
    from aledo tx
    like the tinman said-easy off oven cleaner-then repolish
  7. Blue One
    Blue One
    from Alberta
    Oven cleaner ? Well there you go !
  8. Wrong! Plain old EZ OFF works, the fancy citrus types and low smell versions dont.
  9. Blue One
    Blue One
    from Alberta
    See the post above yours ;)
  10. No shit, but I provided more info since I have done it many times..............:rolleyes:
  11. Da Tinman
    Da Tinman
    Yeah forgot about that part, stinky stuff works much better.
    works better when warm too, thats why the bag and the sunlight....
  12. firingorder1
    firingorder1
    Many thanks Tinman.
  13. Dont leave it to long, it can corrode!
  14. Blue One
    Blue One
    from Alberta
    Your point ? I know it's on the top of your head. You didn't need to point out how wrong I was, I had already done so.
    Providing info ? You should be so proud :D
  15. after reading this thread, i thought , yeah that sounds like a goer. i had some romac full floating axle ends that had crappy anodising on them, so i threw them in a bag with some oven cleaner and left them overnight.
    next day i had a look and....hey presto... completely rooted aluminium axle caps,
    the oven cleaner has sort of corroded the aluminium and rendered the caps useless.
    p.s it didn't strip the anodising off either! :)
  16. Kan Kustom
    Kan Kustom
    New to me.Never heard of the oven cleaner thing before.Thanks.
  17. Da Tinman
    Da Tinman
    shoulda read what Tman said about not leaving it in too long...
    Also your oven cleaner may not be the same oven cleaner we get.
  18. Yes, to reiterate. DO NOT LEAVE THE OVEN CLEANER ON TOO LONG!!!!!!!!!!!! Do a test spot. Those axle ends were prob Hard Ano? This only works on the froo frooo colors. Red, Blue, 3D Violet etc. Even then, do a test and try several quick coats, many times the ano will start to go after a couple tries.
  19. Overnight vs a couple of hours???!!!! Dude....
  20. ronzmtrwrx
    ronzmtrwrx
    I have used the ez off before on the red and blue and it worked for me, but I later bought some anodizing remover from eastwood that worked a lot quicker. Same as with the ez off though you dont want to leave it on there too long.
  21. SMOKINFLATHEAD
    SMOKINFLATHEAD
    from SOCAL
    I just used a small copper or brass(I'm not sure) wire wheel. Harbor freight has them. Put the small wheel in my Dremel, and presto. No chemical, No Color, No damage to the fittings. $.02
