Hot Rods Stromberg 97 adjustable jets
Discussion in 'The Hokey Ass Message Board' started by 1947coupe, Dec 7, 2023.
Tags:
  1. 1947coupe
    1947coupe
    Has anyone used these with success , I was trying to figure out how you would get a baseline setting then fine tune from there, thanks for any info you may have.
  2. Harv
    Harv
    from Sydney
    I did a bunch of test-bench work for various Strommie components. It was aimed at the BXOV-1 carbs used in GM Holdens, but applies pretty well to the EE carbs - exactly the same main metering jets, and can use the same adjustable main jets.
    Disclaimer: I am not a fan of adjustable mains. They were normally used in taxis to chase fuel economy. To tune one for a taxi, wind it in until the car is fuel efficient, then replace the crispy-fried exhaust valves.
    Having said that, the safest bet is to run an exhaust ****yser on a dyno and check you are safe across idle, transition, acceleration, cruise and WOT. When you don't have access to an anaylser, the info below is a good starting point:
    As an initial tuning point, the following may be used:
    · bring the engine up to operating temperature,
    · hold the engine speed at around 3000-3500rpm (mid throttle).
    · Slacken the lock nut on the adjustable jet then screw the adjuster in slowly until the engine speed starts to alter and run a little bit rough. Wind back the adjuster until the engine speed pick up and the engine no longer runs rough.
    · Tighten the lock nut.”
    Whilst this is valid information, if you now roughly what jet your vehicle should have then you can use the info below as a starting point. I then put together the info below by wet testing a variety of fixed jets, and also two typical adjustable main metering jets:
    Opening Equivalent Main Metering Jet (”)
    Two turns 0.043
    Three turns 0.061
    Four Turns 0.067
    Wide, wide open 0.073
    Hope this helps.
    Cheers,
    Harv
    kadillackid, Kiwi 4d, Deuces and 2 others like this.
  3. 1947coupe
    1947coupe
    Thanks for the info, I think I'll contact Clive at stromberg and see what sizes he thinks are best at our 4000 ft al***ude.
  4. Harv
    Harv
    from Sydney
    Clive is good people. Been a few years since I last spoke to him, but give him my regards.
    Cheers,
    Harv
