I wonder if anyone has the edlemann part number for the fitting I need to go to a 5/16 hose. i have one brass fitting on there that needs a male fitting to go into it. thanks drew
Speedway stocks them - don't know the p/n - it's an odd-ish size (1/2-20 maybe?) with an odd-ish seat - have heard a couple of ways to "make it work" using something other than the correct fittings....
I have 4 of those I am not going to use, brand new - 5 bucks a piece with the needle and little gasket PM me 5/16 hose barb - right
I use a compression ferrel,a short piece of brake line and a brake line nut. It does not have a bulb on the end but is not needed at 1.5 psi. You can plumb multiple carbs together with the tubing and then run a hose to one end. Works for me.
