Hot Rods Stromberg 97 inlet fitting help
Discussion in 'The Hokey Ass Message Board' started by CSPIDY, Feb 9, 2025.
  1. CSPIDY
    CSPIDY
    I would like to replace this fitting with one that would adapt to an AN6 and SS braided fuel lines from my fuel block to the carb.
    The threads are 1/2 inch 20 and the flare looks to be automotive 45 degree flare and it seals inside the shutoff fitting in the carb
    There must be name for this fitting?
  2. enjenjo
    enjenjo
    from swanton oh
    That is a 5/16" SAE 45 degree flare fitting. You need to adapt to a AN-6 fitting
    CSPIDY likes this.
  3. CSPIDY
    CSPIDY
    Thank you, every time I did a search it would only come up with a reverse flare.
    I found an adapter to 1/4 inch female pipe which should get me there
