Technical Stromberg 97s versus 48s
Discussion in 'Traditional Customs' started by JohnnyGretsch, Mar 3, 2015.
  1. JohnnyGretsch
    JohnnyGretsch
    I recently scored a dual-carb manifold setup for a 50s Holden to use on my '58 Holden wagon. It came set up with a pair of Stromberg 48 carbs. Is there any merit in swapping them for a pair of 97s?
    Cheers guys,
    Johnny
  2. vwdave30
    vwdave30
    Dont think the ones that are on the intake in the pic are 48's looks like a couple of one barrel carbs.
  3. vwdave30
    vwdave30
    These are 48's
  4. 3wLarry
    3wLarry
    from Owasso, Ok
    they don't look like Stromberg 48's to me...kinda look like Holley 94's
    this is a Stromberg 48
    kidcampbell71 likes this.
  5. vwdave30
    vwdave30
    My bad its early in the mornin and my brain aint woke up yet lol
  6. 3wLarry
    3wLarry
    from Owasso, Ok
    I haven't had my coffee yet either :)
  7. vwdave30
    vwdave30
    The pic i posted is 94's lol i get confused in the morning the funny thing is they are my carbs i know what they are
  8. Gene Boul
    Gene Boul
    48's are slightly bigger but will work just finr...at least in my application they do. Hard to picture a sceinero where 97's work great and 48's just don't work. regardless if they were mine I would clean them up and, if all is visually OK, i'd put kits in them and give it a go. I would think they are worth 250 or so unmolested. g DSC02545.JPG
  9. ct1932ford
    ct1932ford
    I'm running two 48's on my coupe built 48 Merc. motor and two 97's on my roadster built 33 motor. Both cars run great. What is the rest of the motor like?
  10. Mike51Merc
    Mike51Merc
    Here's a pair of 48s. The OP doesn't have 48s.
  11. Paul
    Paul
    Editor
    Probably two stock 1 barrel Strombergs.
    I'd rebuild them and give them a try, likely they are what the intake was designed to run.
  12. oldcarguygazok
    oldcarguygazok
    from AUSTRALIA.
    The old grey's only need a single strommy to run fine,having 2 is ok, for some oomf,like having to much coffee,lol,they're easy to rebuild and practical,need to see some pics of the fe/fc wagon,good luck,Gaz!
  13. Kiwi 4d
    Kiwi 4d
    These appear to be the old original holden carbs. Not stromberg 48s.
    run the two as is cos you already own them.
  14. JohnnyGretsch
    JohnnyGretsch
    Cheers for the replies, guys! It looks they are the factory type single-barrel Strombergs. Sorry for the misidentification, I've spent most of my time wrenching on Holley-equipped Y-blocks so this stuff is new to me.
  15. JohnnyGretsch
    JohnnyGretsch
    This is the "good one". It was my Dads first car, and was identical to the one my grandfather and great grandfather drove. This one will be a mild custom, and the spare car will be me and a mate of mines g***er project.
  16. 40fordtudor
    40fordtudor
    I was told way back in Neanderthal times that the 48's flow better. That's is all I have.
  17. amodel25
    amodel25
    I'm pretty sure those are Stromberg 847's that came stock on 49-51 flathead Ford 6 cylinder. I ran 2 on my avatar for several years. They are sort of half a Stromberg 97.
