Stromberg Aerotypes....can anyone school me?
Discussion in 'The Hokey Ass Message Board' started by D Picasso, Oct 9, 2003.
  1. D Picasso
    D Picasso
    got a couple of these crusty things out in the shed, and I have to confess I've never worked on one of these, nor do I know anything of their capabilities. you?
  2. briggs&strattonChev
    briggs&strattonChev
    BTTT, I hate to see a guy go with zero responses to his inquisitive post......................
    stromberg aerotypes aka stereotypes lol (ok that ****ed)
  3. ShortBus
    ShortBus
    Are they Stude or something else? My early 60s GMC 305 v6 ran a Bendix-Stromberg Aerotype WW2. I can scan my factory manual that deals with that particular model if it'll help. Other than that, I know squat.
    lemme know.
    R
  4. D Picasso
    D Picasso
    hey Rick,
    well, I checked the numbers as much as I could and I'm thinking they may have been OE on a straight Buick or Pontiac. I lack general knowledge on 'em overall.
    lemme check the numbers again....
    OK, here we are.... on the base, next the left idle screw is a stamped "40" then over to the right is serial No. 335829. nice written-in-clouds 'Aerotype' logo. made in Elmira, New York.
    on the other side is the model designation AAVB then over to the right appears '267'.
    sure, I'll take you up on that manual scan. thanks!
  5. D Picasso
    D Picasso
  6. D Picasso
    D Picasso
    anybody else?
  7. D Picasso
    D Picasso
  8. manyolcars
    manyolcars
    I have many pages of info and photos but no scanner. What do you want to know?
  9. manyolcars
    manyolcars
    quote----> All strombergs are similar in construction. AA series are dual barrel downdraftwith two floats. AAV has vac*** power system (other models have mechanical power jet action). AAVB-267 was used on 1950-51 Series 70 Buick only. My books cover 1935 to 1956 The other Strombergs were used on 1935-36 Auburn,Buicks 1935 to 1955, Cadillac and LaSalle 1935-48, Chevy 40-54, Chrysler35-58, DeSoto and Dodge 35-48, Ford-Mercury 35-51, Lincoln 35-42, Frazer, Hudson, Kaiser, Nash,Olds, Packard, Plymouth, Pontiac, Studebaker, and Willys. ALL carb ***embly numbers are 380**x, I dont see 335829 anywhere. Are you sure about that number? I can give you float setting--21/32 measured from top of body with no gasket. What else?
  10. D Picasso
    D Picasso
    thanks man, that helps a lot. I'll doublecheck that number. is this a cooperative carb, more or less? are kits a bear to find? I was thinking about running them on the Olds; got an Edmunds manifold to put 'em on. or....does it seem like running two Rochesters is a better idea? like I said, I'm a babe in the woods when it comes to Strombergs.
  11. rodnkustom
    rodnkustom
    I think I remember Marcus having a later style edmunds intake w/ two of those carbs on it. Can't remember completely though, was like 7 or 8 months ago, maybe longer.
    -peter
  12. Fraz
    Fraz
    from Dixon, MO
    Frazer had em? Hmm, looks like I need to go and look at my motor again. Might have another for ya FA.
  13. manyolcars
    manyolcars
    Frazier, 1947-48 only. This is a Chiltons Motor Manual. Its kinda hard to believe---I've NEVER seen one of these on a Ford. Has anyone else?
  14. Fraz
    Fraz
    from Dixon, MO
    That's FraZER and mine is a 48.
  15. Anyone have any pics of these carbs ?
  16. Bodger45
    Bodger45
    I'll send you the illustration Friday when I have access to my scanner. It's wierd I was just looking at it last night. TK
  17. In Australia, they turn up on flathead Cad.s and straight 8 Buicks. One carb I have has had its base modified by braze welding to change it to a three bolt base. Someone told me people would run them on flathead Ford V8s at dirt tracks. There looks to be a few different models with different looking float bowl bodies. I've got a couple that I want to run on an Edmunds dual intake for my 331" Cad OHV. I'm keen to find out where rebuild kits are available from. Stromberg always made a pretty simple carb to work on. I'm sure they'll work well once freshend up. CM
  18. Bodger45
    Bodger45
    My book shows it on '50 to'54 Buick straight 8's. The Cadillac AAV-26 look the same but don't have the starting switch. Your carb part no. didn't seem right.
    Let me know if you need the service parts list. TK
  19. carbking
    carbking
    The Stromberg "Aerotype" carburetor was so named (according to Stromberg) because it was an aircraft design.
    The Aerotype designation refers to a number of different styles of carburetor of type "A" (follow the link below for more information on the various Stromberg types):
    http://www.thecarburetorshop.com/Strombergcodebreakdown.htm
    Just got a telephone call, more later.
    Jon.
  20. flatheadjunk
    flatheadjunk
    from Orange CA
    Be careful-------some of the Aerotypes did not have an idle circuit,I don't remember which but I am sure some of the info available will help you decipher what you have.
  21. carbking
    carbking
    OK, back again, continuation of previous post.
    The Stromberg Aerotype carbs were produced (production) from 1937 through about 1955. The type A (Aerotype) was superceded by the type W (W - single, WW - S.A.E. size 2 dual, and WWC - S.A.E. size 3 dual)
    Stromberg Aerotypes were produced as O.E. on Buick, Cadillac, Packard, Studebaker, and several military applications including Cadillac tank engines.
    Stromberg Aerotypes were also produced as A/M for many different vehicles.
    (Opinion) one of the very best two barrel carbs ever produced.
    Jon.
  22. Redbows35panel
    Redbows35panel
    Kits are available from AFLA Products, Inc. 1433 Fairbrook Dr. Des Perse, Mo. 63131, (314) 821-6037.;)
  23. F&J
    F&J
    I am guessing that many Edmunds 2x2 manifolds were built for the Aerotypes. I have seen quite a few crusty as-found intakes pictured on the net with those carbs.
    They were on the factory early 40's Buick straight 8 that came with 2x2 as well.
  24. G V Gordon
    G V Gordon
    from Enid OK
    I used to have a 4X2 Olds log manifold with four of those. That was also what was on my '50 buick I8. Used on a lot of the bigger GMs in the 50's. If you have an old Motors or Chiltons they should have info in them.
