Technical Stromberg float ball
Discussion in 'Traditional Hot Rods' started by Ron Plumlee, Jul 13, 2024.
  1. Ron Plumlee
    Ron Plumlee
    Stromberg 97 question: have two new stromberg 97s, all good except front carb has the float ball stuck if the car sits for a few weeks. Any suggestions? I get the ideas of fuel pressure residual, fuel pressure etc, but hoping maybe there is a simple gas additive that might help. They are on a flathead, mechanical pump. I searched some previous related posts, didn't see an answer. I know, easy fix just fire it up every few days.
  2. 302GMC
    302GMC
    from Idaho
    Take it apart & fix it ?
  3. alchemy
    alchemy
    Do you mean the grose jet ball on the inlet? Some guys prefer the pointed tip inlet valves, and that might be the reason why.
    Andy likes this.
  4. oj
    oj
    I'm with alchemy, define what you mean by 'float ball' and how do you know it gets stuck?
  5. Ron Plumlee
    Ron Plumlee
    I
  6. Ron Plumlee
    Ron Plumlee
    Its the steel ball a little bigger than a BB, it shuts gas off when the float gets up, if it sticks in the "open" position, gas pours out the top of the float bowl. If you disconnect the fuel line to that carb, remove the fitting with the ball in it, loosen the ball and all is well. Same carb every time.
    oj likes this.
  7. carbking
    carbking
    Had this on my website for a long time, it is still applicable:
    https://www.thecarburetorshop.com/Fuel_valves.htm
    EDIT: since I wrote that article, subsequent interaction with customers indicates the valves work fairly well (other than fuel flow) for carburetors in which the valve hangs from the top (Carter AFB, Rochester 2GC, etc.) but tends to give more problems when fastened in the bottom of the bowl (many older updrafts) or is mounted on its side (Rochester Q-Jet or Stromberg EE-1, called by some the "97").
    When still rebuilding carbs, this valve was an no no. If the customer demanded the use of this valve, we would politely suggest a different shop, as we would not use it.
    Jon
    oj and saltracer219 like this.
  8. alchemy
    alchemy
    Well, Stromberg currently uses the ball valves in their new production carbs. Not sure where to get good pointed type valves if you want to try them.
  9. 38bill
    38bill
    from Minnesota
    Are we talking about new true English 97's or the copies? If they are the English 97's you should contact Clive at Stromberg and I bet he will help you out.
  10. alchemy
    alchemy
