Can any one help me figure out what type of Stromberg I have. I got a 3-2 setup with 97 secondaries and I think a 48 primary. the body says 1 1/32 which tells me it is a 48, but the idle jets,emulsion tubes are different than the 97s, which I thought were the all the same. The emulsion tubes are much larger diameter, like 3/32" bigger, on the main jet end and there are four large holes around the recessed collar on that end, along with the other seven smaller ones along the tube and around the venturi end. The idle jets dont have the small taper tip on the bottom and they also have a check ball in them. I need to order parts and I am not sure what I have. Thanks
