Stromberg Question
Discussion in 'The Hokey Ass Message Board' started by keeper, Apr 2, 2009.
  1. keeper
    keeper
    from So Cal
    I would like some help learning the differences between the 2 Stromberg bases I have here. The one on the right has a large EE-1 while the one on the left has EE7. As you can see in the photos the one on the left has had some brazing added to it. I have searched for the differences using EE-1 and EE7 but I am not having much luck.
    Is one a primary and one a secondary. The mounting holes are different on the base. And for the set up I am trying to use it looks like I will need two EE-1, is that typical?
  2. SinisterCustom
    SinisterCustom
  3. Bruce Lancaster
    Bruce Lancaster
    D shaped is an early Stromberg, 1934 til almost end of production, triangular base very late production. There are no secondary ones. The late base comes with off-idle ports like early and with off idle ports extended out. I think the brazing repairs a botched attempt to add a vacuum port. Mounting holes should be the same, outer shape only is different. Triangulated base visually matches Ford carbs.
  4. keeper
    keeper
    from So Cal
    Thank you for the quick help.
    Does anyone have a EE-1 base they would like to sell?
