Stromberg Single Barrels
Discussion in 'The Hokey Ass Message Board' started by Tex_06, Dec 29, 2012.
  1. Tex_06
    Tex_06
    That title almost sounds like a whiskey :D
    I was wondering if anyone could enlighten me with the differences between an BXOV-2 and -3 besides the base size and why only the automatic vehicles ran them, the BXV-3 and BXVD-35.
    I've got a 235 (bored .30 over) with a 3/4 cam from Delta Cams, Fenton repro dual carb intake (2 15/16" bolt spacing, hence the question), Fenton cast iron headders, and a ported/polished head. This is all in a 4-spd '60 Chevy truck. I'm afraid I'll over carb the motor if I use two of these BXVD-35 carbs I found locally.
    Any help would be greatly appreciated!
  2. carbking
    carbking
  3. Tex_06
    Tex_06
    Thanks Jon, that did help some. From what I understand, if I want to keep the manual choke, a -3 car would be better. The guy says he has an old plymouth BXUV-3 that would work, but I'd need to find another to match it.
    I believe the top of the carb has a 15-22 stamped into it....does this need to match on my other carb? If not, how can I tell if the jets are similarly sized?
  4. carbking
    carbking
    With your engine, I would suggest 2 of the size 2 carbs, and redrill and rethread the intake.
    For best results, the carbs should match.
    Any there is a LOT more to matching the carbs than just the jets. There are several different internal venturi sizes for each of either the size 2 or size 3 carbs.
    Two size 2 carbs will give you better low end. Two size 3 carbs MIGHT give you a couple more horses at W.O.T. only. Trailer race car....use the size 3's, but for street, you will probably be happier with the 2's.
    Jon.
  5. Flop
    Flop
    i have 2 bxov-2 carbs on a mostly stock 216 ----besides headers .. it runs a tad rich but i am very happy with the carbs . they have been running great coming up on 3 years now!
  6. sport fury
    sport fury
    there is a hamb thread called 1953 stromberg carburetor catalog. it may list the specs you are looking for
  7. Tex_06
    Tex_06
    Thanks for the all the help!
