Well...technology bit me in the ass.... I'm in the process of rebuilding a WW off a 318. Took pictures of everything with my phone, and then my phone crashed. Where did the pictures go? Hard to say. So now I'm close to having it done and stuck. Mostly with the small side linkages. I've tried Google searching for some decent pics with no luck. Anybody know these like the back of their hand?
What do you need to know ? http://www.jalopyjournal.com/forum/threads/tech-stromberg-ww-rebuild-with-pix.96174/
The one that has me most baffled is on the driver's side. It's a link that goes from the top "butterfly" to what I think is something called the "start assist lock".(?) I forgot to snap some pictures, and I'm at work now. I'll try and snap a few this evening.
I think I've got it figured out. Did some more digging and found a couple pictures that are close. My other problem is figuring out the linkage. It's originally off a 65 Fury I believe. It appears to be set up for a cable (pull) setup. So i need to alter the linkage for a push setup.
