Hot Rods strombergs with c4
Discussion in 'The Hokey Ass Message Board' started by 4ford, Jul 27, 2018.
  1. 4ford
    4ford
    from Eagan. Mn
    any one ever installed a c4 trans with a flathead and used the kick down lever or cable with two Stromberg's on it and if so any ideas or even pictures??
    thank you
    mike
  2. silent rick
    silent rick
    back to the top for you
  3. F-ONE
    F-ONE
    from Alabama
    I have not run duals so take this for what it's worth........
    I think a good shifter and downshifting manually is your best bet in the long run.
    3340 likes this.
  4. jimmy six
    jimmy six
    Not on a C4 but a Cruise-o-Matic works the same. Vacuum modulator controls normal shifting and the kick down lever on the side of the trans does the kick down. I see no reason you can't get a cable made and make a bracket near the trans to hold it. On the carb end have it be like a typical tv cable with a lot of adjustable threads and slot placed on the end of the cable. As you operate your 2 Strombergs in tandem they move in the slot and at the very end it moves the cable pulling on the trans arm down shifting the trans. I did it on a cruise-o with a dual quad set-up, I had to keep adjusting the slot until it would only down shift right at the end. I didn't use a cable buts exactly the same principle. Good luck.
  5. 4ford
    4ford
    from Eagan. Mn
    yes that's what I was thinking. and as F1 said just down shift it I think tats a good alterative till I figure it out just thought someone had did this and had some pics of the set up at the carbs it would make it a little easier. I do have the lever on the trans just need to make up a cable.
  6. cartman4gc
    cartman4gc
    I've done this, lokar has what you need
  7. 4ford
    4ford
    from Eagan. Mn
    lokar is what i want do they have the link for carbs??
  8. 3340
    3340
    I just pull it back in 2, however on my 31 roadster w dual 94’s can’t ever remember doing that!
    Sent from my iPhone using The H.A.M.B. mobile app[​IMG]
  9. FrozenMerc
    FrozenMerc
    Used the Lokar cable setup on a buddies '48 with 2 Demons and a C4. Worked great. Not the best picture, but it is the only one I have.
    bct likes this.
