Stromburg 97. Completely stock. No damage. Never in carb cleaner or bead blasted. Original finish on body. Dis***embled and inspected. All as new. Accelerator tubes flow tested.New kit installed. Stainless screws installed. Everything works as new. Original jetting. I was building the carbs for my own usage using the best of a large stock of cores. This is as good as I can do. I did forget to put the little cotter pin in the accelerator pump linkage. I will take care of it. I have two more identical carbs.
