Technical Stubborn Intake/Exhaust Mani
Discussion in 'The Hokey Ass Message Board' started by LongLiveFlathead6, Mar 3, 2015.
  1. LongLiveFlathead6
    LongLiveFlathead6
    Last night was a long night... What I thought was going to be a simple night turned into a nightmare... I removed the head from my MoPar flathead 6 with ease and minimal problems... So then I decided to move on to the intake and exhaust manifolds to continue cleanup of the engine...
    At first, everything was going fine... Until I removed all nuts and spacers.... Then I could not get the manifold OFF... it was absolutely seized...
    I tried penetrating lube, WD40, hammer, and pry bar... I tried what I could without damaging anything and nothing work...
    If anyone has any suggestions It would be absolutely appreciated...
    Thank you!
  2. saltflats
    saltflats
    from Missouri
    Not to be a smart *** but I ***ume you got all the bolts out.
  3. Frankie47
    Frankie47
    from omaha ne.
    There is one hidden one, you better look again.........
  4. raff23089
    raff23089
    If I recall there is a couple of bolts tucked in the area under the carb. Might be hard to see if it's full of grease and ***orted crud. I've fought with the bolts and studs on a couple of mopar flatties but once they're out the manifold falls off.
  5. RichFox
    RichFox
    yeah. it would come off if all the bolts are out.
  6. LongLiveFlathead6
    LongLiveFlathead6
    It was late and I had a few beers in me, and I was alone and I usualy have a buddy there to catch what I miss... I am sure I removed all nuts, but I will go back out in a bit and verify if I did remove them all...
  7. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Been there before. Thought I had them all (also on a dodge flat 6), turned out I missed a hidden one, dang near fell off then.
  8. 302GMC
    302GMC
    from Idaho
    You may have to dig - years of crud can completely cover the undersides of the ports & hardware. It WILL fall off when unbolted ...
  9. LongLiveFlathead6
    LongLiveFlathead6
    Yes... you were all right... I didnt just miss one.... but two... I still couldnt really see the two bolts that I missed, but I had my son get his head in there and he confirmed that there were two more bolts...
    I scratched my head for hours last night and it only took my son and about 30 sec this afternoon...
    302GMC likes this.
