Technical stuck banjo pinion
Discussion in 'The Hokey Ass Message Board' started by topher5150, Jan 28, 2018.
  1. topher5150
    topher5150
    Looking at all the posts about taking out the Ford banjo pinon gear you push from the inside and it pops out. We'll I did that and now it's still stuck. What am I not doing right IMG_20180128_164559372.jpg
  2. Poh
    Poh
    from Quincy,Ca.
    Heat up the housing quickly to expand it , and try again., or shrink the bearing race by Welding a bead around it and try again
  3. topher5150
    topher5150
    What is a bearing race?
  4. greybeard360
    greybeard360
    That's where you take two bearings and roll them across the floor and see which one gets there first.
    Sorry.... Just had to.
    Sent from my Moto G Play using The H.A.M.B. mobile app
    MAD 034, Texas Webb and big duece like this.
  5. gimpyshotrods
    gimpyshotrods
    Here are the pages from the service manual:
    Poh and Donuts & Peelouts like this.
  6. gimpyshotrods
    gimpyshotrods
    You cannot do that with this setup. The pinion bearings are a cartridge, which is two races, as one piece, back-to-back. That is pressed in, and pressed out. Even if you take the nuts off, and pull out the forward bearing cone, you would only get to that side of the cartridge, and you'd risk trashing the pinion by welding near it.
    Poh likes this.
  7. seabeecmc
    seabeecmc
    Easy with a whipped up pusher/puller. Please do not use a small bottle jack inside case! Ron
    pull5.JPG [​IMG]
    bct likes this.
  8. PHIL COOPY
    PHIL COOPY
    Made this tool...it works fine. Don't line the bolts up with the holes as shown instead place something under them to protect the threads. Impact wrench shown but didn't need it.
    bct likes this.
  9. topher5150
    topher5150
    I really wish they'd let us use the press at work. I was trying with a scissor jack in a vice yesterday. Probably gonna have to see if the maker space has a press and a torch.
