Technical Stuck bolts in carb
Discussion in 'The Hokey Ass Message Board' started by Hellfish, May 10, 2023.
  1. Hellfish
    Hellfish
    Any suggestions for freeing steel banjo bolts stuck in a pot metal carb?
    SU HD8 carb
    In one carb I tried Kroil and PB Blaster, an HF sonic cleaner (useless), and heat with Oxy-MAPP and finally broke the float bowl lid trying the free it. I can get a replacement, but I don't want to just keep throwing money at it, and the final carb has 2 stuck banjos.
    I was able to free up the idle adjustment screw on the other carbs with the above methods, plus boiling it in water.
    A working set is worth decent money, so I don't want to just give up on it.
    More heat? Acetone+ATF? An impact would probably break it.
    Deuces likes this.
  2. saltflats
    saltflats
    from Missouri
    Have you tried tapping it with a hammer?
  3. Hellfish
    Hellfish
    Yes. Not hard, but from fairly good whacks to small taps while trying to tighten/loosen the bolt.
    Deuces likes this.
  4. saltflats
    saltflats
    from Missouri
    Maybe one of those hand impacts drivers that you use a hammer on.
    loudbang and Deuces like this.
  5. '29 Gizmo
    '29 Gizmo
    from UK
    May need to drill it out. Pot metal can litteraly fuse to steel components.
    Boneyard51 likes this.
  6. Boneyard51
    Boneyard51
    Might take an impact wrench and set it on a very low setting, almost nothing, and let it kinda “ vibrate “ the bolt for a while. Might combine that with your heat. Also you might try concentrating the heat on the bolt, to expand the bolt , then let it cool before trying to turn it, several times. Lastly , if you can replace the banjo connector, you might drill it out to relieve pressure .
    Bones
  7. Sometimes it's hard to tell where the actual "stuck" part is. Is it the threads in the body, or is the bolt stuck to the fitting. I've had some luck , just concentrating heat, with a small flame, on the exposed part of the bolt(head), and letting the heat soak in to it, several times. Some of the guys at work, will quench it, and the shock helps release the bond. I will, spray it with some good rust penetrant- PB or acteone/ATF.
    Just some suggestions.
  8. Nailhead Jason
    Nailhead Jason
    last one i did was on some side draft Webers. I put the carbs in a vice to hold it. Then heated the base where the bolt threads in with a Mapp gas torch, then had a wrench on the bolt pulling to loosen the bolt while tapping the bolt head with a small ball peen using the round end to hit the bolt and not the wrench. Took awhile but one came out perfect, the other came out and took some threads with it. I found a thread insert repair kit on line for weber inlets and took care of the messed up threads. Good luck with it, those can be a real ***** if you have to get them out.
  9. Heat the screw head and drip wax at the base of the head
    62rebel likes this.
  10. PotmetalB
    PotmetalB
    It doesn't actually fuse, but when it's molten and surrounds a dissimilar metal part, as it cools, it shrinks so tightly, it's like a bond. I've done it many times. Works well, but depending on the stress of said part, one can use a higher grade meterial and not need the other at all.
    Just food for thought...
