Technical Stuck Harmonic Balancer
Discussion in 'The Hokey Ass Message Board' started by seb fontana, Apr 16, 2015.
  1. seb fontana
    seb fontana
    from ct
    A guy I know has a blown BBC and is trying to get the balancer off, crank is double keyed because of blower drive...He is using a puller and it moved about half way and stopped, stuck....He tried more force and heat and no budge..He hasn't resorted to cutting it off [well as of the 11th] so any advice? Engine is out of truck and pan off and he doesn't plan to reuse balancer as is upgrading..I said I would ask at the best place knew; Thoughts? ...
  2. indcontrols
    indcontrols
    I blasted a nitrous line onto the center of the crank to freeze it and pull one off once, worked like a charm...
    frazzledsmythy likes this.
  3. saltflats
    saltflats
    from Missouri
    Tell him to make sure he took the washer out of the center hole.
  4. seb fontana
    seb fontana
    from ct
    Wouldn't have moved half way if he left the washer in...
  5. squirrel
    might have galled, in which case it probably needs to be cut off.
  6. Yep. That's my guess.
  7. Atwater Mike
    Atwater Mike
    Die grinder, series of shallow cuts. (puller installed, damper will move when stress is relieved.)
  8. frazzledsmythy
    frazzledsmythy
    Dry ice might work too. Or pull the crank and press it off with a shop press.
  9. seb fontana
    seb fontana
    from ct
    Thanks guys, he's probably took a hachet to it by now..LOL..We did figure that cutting it was going to have to be done because it galled somewheres...He blames the double keys not being precise enough alignment..I'll see him Friday night or find him on Facebook...Thanks....
  10. seb fontana
    seb fontana
    from ct
    Found him on Face Book..He got a 5 ton gear puller and got it off..Found one of the keys burred up...Thanks guys..
