stuck king pins
Discussion in 'The Hokey Ass Message Board' started by fattrodder, Sep 29, 2007.
  1. fattrodder
    fattrodder
    i just bought a front and rear suspension off a 39 ford stocker that is being rodded.50 bucks.i took all the front apart but can not get the king pins out .ive tried heat, breakaway. any ideas. i also got the wide five wheels too.
  2. 40chev
    40chev
    The only thing I know of is heat and lots of it, a little hand help propane bottle wont get it, you'll need a set of torches.....Heat it and beat it, that rust is like weld....
  3. Hackerbilt
    Hackerbilt
    But don't heat & beat them till they flare on the bottom or you'll REALLY have a problem!!!
    Maybe you know someone with a good hydraulic press???
  4. zzford
    zzford
    try heating it , then melt a candle using the spindle boss for the heat source, wick the wax into the boss as though you were soldering copper pipe.
  5. I'm sure you did, but I'll ask anyway; did you remove the kingpin lock bolt?
    Sometimes little things get missed....
  6. SchlottyD
    SchlottyD
    I took one of mine out at work with a 50 ton press, and it was straining, got the other one part way out with it, now it' stuck as can be again, fun for me.:eek:
  7. Kirk Hanning
    Kirk Hanning
    Of course heat , which has already been mentioned. What has always helped me also was a pointy tip on the ol air chisel. The combo of heat/vibration/constant pressure has always served me well. In fact I welded a drift punch to a wore out air chisel bit and NEVER had a problem with stuck door hinge pins either.
  8. SlowandLow63
    SlowandLow63
    from Central NJ
    Welcome to the wonderful world of kingpins. But hell, after all, they are stronger than balljoints.
