Technical Stuck with an odd clutch
Discussion in 'The Hokey Ass Message Board' started by vtwhead, Jul 1, 2024.
  1. vtwhead
    vtwhead
    I have been trying to get a 51 Chev truck running. It has been a trying experience. And now, with the engine out, we have found that we need a new clutch. One would think that would not really be a difficult issue but in this case the truck was equipped with the heavy duty 10 3/4 inch 9 bolt unit. I have looked around and the two vendors that i spoke to have no stock and no anticipated ETA for new stock. Hoping someone can suggest an outlet that might have one or as a last resort a company that can rebuild the OE piece that might be east of the Mississippi.
    This is the pressure plate we are dealing with. It is destined to go behind a 54 235.
    Algoma56 and Tow Truck Tom like this.
  2. squirrel
    might be easier to find a different flywheel?
    then if you get the 55-later version, you can use a 12v starter with it, as well.
    The weird thing is that I though only GMCs used the 9 bolt pressure plate. Are you sure it's a Chevy engine? Or is this just one of those things I didn't know about old Chevy trucks?
    Paul, Algoma56 and Tow Truck Tom like this.
  3. AVater
    AVater
    Walt,
    Looks like you’re still having fun on this “challenge”. Best wishes & say Hello to Bruce for me.
  4. 302GMC
    302GMC
    from Idaho
    That's the version that came with the 4 speed as standard equipment & HD in 3 speed cars & trucks. Most farming state dealers wouldn't order anything else in a truck. If used would work for you, PM me.
    Algoma56, Tow Truck Tom and squirrel like this.
  5. Fordors
    Fordors
    I had a ‘73 Cutl***, I ordered it with a 4 speed. Still have the pressure plate and I think a six bolt pp might work on your flywheel. The dimensions are as follows-
    Bolt circle diameter - 11 5/8, C to C of bolt holes - 5 13/16
    My clutch is 10 1/2” but you never know, a six bolt might bolt to your flywheel.
    One other thing, there are low and high diaphragm pp’s, mine is high but there were also short and long throw out bearings if you find a high diaphragm plate that works for you.
    Algoma56 likes this.
  6. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I like Squirel's idea.
    Meanwhile have you talked to Fort Wayne Clutch? Likely they can help
  7. 51504bat
    51504bat
  8. I called Fort Wayne Clutch and was able to source the clutch I needed. I didn't think it would be tough to find but it was. However, one quick phone call to Fort Wayne Clutch, they had what I needed in stock and sent it to me very quickly. Excellent service.
  9. cshades
    cshades
    from wi
    i ran in to the same problem with a 41 chevy 3/4 ton with a 216. so yes they did use them on chevy trucks. i lucked out and found a guy locally that had a bunch of nos gm parts. lo and behold he had one in stock it was a bit rusty but cleaned up. he was happy to sell it and i was very happy to get it.
  10. vtwhead
    vtwhead
    Yes, this was behind a 51 216 3/4 ton truck as well. I have a call into Ft Wayne clutch to see what they can offer.
  11. ekimneirbo
    ekimneirbo
    from Brooks Ky
  12. vtwhead
    vtwhead
    Thank you! I have emailed them with the specs.
  13. Mr48chev
    You may have to have your clutch rebuilt.
    Truckdoctor Andy and Algoma56 like this.
  14. vtwhead
    vtwhead
    Wow, Ft Wayne had a new unit but it is $500 after exchange. Ky. Clutch wanted 175 with a one day turn around on rebuilding our unit. Just shipped it to them. Thanks fellas for all the input.
  15. ekimneirbo
    ekimneirbo
    from Brooks Ky
    ;);););););););););););););););););););););););););););):D
  16. 51504bat
    51504bat
    Ft. Wayne Clutch used to be the place for flathead clutches but from what I've heard not so much anymore. Glad Kentucky Clutch came through for you. Let us know once you get it back and installed.
  17. 05snopro440
    05snopro440
  18. vtwhead
    vtwhead
    Yeh, they like most show them but not in stock and no eta.
