Hot Rods Stud welder for dent removal
Discussion in 'The Hokey Ass Message Board' started by dirt car, Apr 22, 2026 at 5:34 PM.
  1. dirt car
    dirt car
    from nebraska
    I've some collision damage on my 32 that is inaccessible without removing quarter panel internal bracing & curious to know if anyone has had favorable results with the Harbor Freight Chicago brand stud welder to pull dents as needed. I know a variety of name brand units are out there in all price ranges, just needing a unit that fits my budget & 80 plus years.
    51 mercules likes this.
  2. Jack Rice
    Jack Rice
    I recently purchased a H-F stud welder kit. It seems to work pretty well for my non-professional use. Just make sure the metal is clean and bare for a good contact and a strong weld.
    TrailerTrashToo likes this.
  3. dirt car
    dirt car
    from nebraska
    Thanks Jack, I additionally read the H-F reviews for all it might be worth, but favor comments such as yours from known users, reasonable at $90 or so, it might save the inner structure & avoid opening another can of worms, so far removed the rivets from the tweaked upright that the rumble seat hinges on as I know that needs to be correct for gap & proper function, hoping to dolly work it straight but available from UPI as a pair if all else fails. incidentally it's not my avatar I'm hammering on this go around, but rather my 32 Sport Coupe. Ron
  4. jimmy six
    jimmy six
    I have 2 small dents in a window trim stainless I’d like to try one of the glue on kits a try to pull them out. I’d like to know if anyone had tried it….no guts for me yet!
    dirt car likes this.
  5. vtx1800
    vtx1800
    bschwoeble likes this.
  6. 1946caddy
    1946caddy
    from washington
    I bought one several years ago and when I opened the package, I had the same problem with the slide hammer not gripping the pin. I took it back to the store and the manager opened about six different boxes until we found one that worked. We just exchanged items and I was happy.
    warhorseracing likes this.
  7. I have one...it has worked fine anytime I've called it into action. The slide hammer can slip at times, but I found that simply re-installing and tightening the grip of the teeth on the stud usually gives enough pull to move the sheetmetal.
  8. Charlietruck62
    Charlietruck62
    I threw away the slode hammer after getting one of these
  9. It’s ok
    The slide pull can sometimes ****
    I’ve pulled a lot of dents out with em
  10. flynbrian48
    flynbrian48
    Like the others, I bought an HF stud welder and have had no problems. I haven’t had the slide hanger not grip, and have used it on a couple pretty big jobs. For the price, it’s well worth having it in the shop.
  11. lewk
    lewk
    from Mt
    I've got one. My skill level and the tool's quality go well together... We find our way through.
  12. As much as I generally hate hobo freight I actually have been using a Chicago electric stud welder from there for years with great results
  13. dirt car
    dirt car
    from nebraska
    My most immediate concern beyond the bow in the right quarter is the reveal line that parallels either side of the deck lid & the reveal that flows along & down the sides of the right quarter panel, this area was pushed forward & under with several crease lines remaining after using a porta-power to push the quarters back to accommodate test fitting a new UPI complete tail pan. I see minimal relief on the quarter bow after pushing beyond the original position with the rear most body bolt removed & will do more inching my way while allowing for a degree of spring back. The original topic H-F tool I'm hoping will come into play on those mentioned reveals, although the stoutness of any stamped bead reveal I'm a bit apprehensive the studs with have enough staying power to permit sufficient pull, but will give it a try. Things are a bit complicated as the sub-rail & wheel well show minor buckling which I lightly m***age while pushing to the rear & may well involve some heat application, beyond the trashed frame horns have not found evidence of any over the axle frame damage.
