Technical Stude Pickup Warehouse Find
Discussion in 'The Hokey Ass Message Board' started by bchctybob, Oct 30, 2021.
  1. vtwhead
    vtwhead
    Jacksmith and bchctybob like this.
  2. 2Blue2
    2Blue2
    Nice looking welds.
    Atwater Mike and bchctybob like this.
  3. bchctybob
    bchctybob
    Thanks for the link Walt, but that is addressing the 10Si w/internal regulator, I'm using the 10DN with the external regulator, quite a different setup. That's mostly what I found scouring the internet, mostly 10Si info.
  4. bchctybob
    bchctybob
    Thanks. It was an unusual day, my eyes were working, my gl***es were clean and I got the welder setting right. Usually, at least one of the three is screwed up!
    brEad likes this.
  5. vtwhead
    vtwhead
    Bob, senior moment there I guess. Looked up an Olds wiring diagram for a 69 that has all the compnents. This might help
  6. bchctybob
    bchctybob
    Thanks, you were reading my mind. I was going to look up a ‘65 Chevy wiring diagram and see what that looks like. Funny, all these years I’ve been deleting idiot lights and hooking up gauges, this is the first time I’ve actually hooked them up, uncharted territory for me. The oil pressure will be on the idiot light system too (with an old SW mechanical gauge as backup)
    I got most of the wiring done yesterday. I removed a bunch of unused wires and some length from some that were just looped around. I’m intrigued by the unusual fuse block, although only a few of the available circuits were in use. I’ll post a picture of it.
    brEad likes this.
  7. bchctybob
    bchctybob
    Here’s the fuse panel. The fuse holders stick straight up, twist lock type, like half of an in-line gl*** fuse holder. Never seen this type before, maybe it’s stock Studebaker? My other Stude pickup had the more conventional lay down fuses.
    5FF75CB8-0479-4822-AF56-D15AC622B840.jpeg 7A82A25C-9A13-4331-BCC5-4B2845A5BD43.jpeg
  8. vtwhead
    vtwhead
    Oh yea, I bet the parts store guys know exactly what those fuses are:)
    bchctybob likes this.
  9. I believe I would go modern.
    Ben
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    I am sure there are just normal gl*** fuses in there, if the contacts are clean I would not have a problem using it. The less "modern ****" the better.... just my humble opinion, your results may vary
  11. BamaMav
    BamaMav
    from Berry, AL
    Me too. I’d get a fuse block that still took the gl*** fuses and replace that rats nest. If that plastic is like most that age, it’s probably brittle and will break with vibration. It looks like the inline fuse holders that came with radios, They would last a few years then the little tabs would break off and not stay together. I doubt you’ll find any replacement fuse holders for that block except maybe at an old electronics dealer.
  12. TA DAD
    TA DAD
    from NC
    Cole Hersee makes nice gl*** fuse blocks.
  13. ccain
    ccain
    Looks like you have to be half mechanic and half switchboard operator to fiddle with that fuse box.
    "Hello Sarah, get Thelma Lou. What? Yeah, I know I have a bad ground, just get me Thelma Lou."
    :p
    brEad, SS327 and bchctybob like this.
  14. bchctybob
    bchctybob
    I totally agree. I had to run a few new wires in the charging circuit because my conscience wouldn’t let me re-use the hard, cracked wire but the new wire and clamps stand out like a sore thumb to me.
    You push down and twist and they pop out. There’s a regular old gl*** fuse inside. It seems to be in pretty good shape. There are 12 “circuits” but they apparently only used two plus the flasher holder. I have six fuse holders.
    I’ve put 12v to the system and nothing sparked or smoked, but turning the ignition key did nothing either so….
    Moriarity likes this.
  15. bchctybob
    bchctybob
    Yep. And you have to be 7 feet tall with long arms to work on anything on the firewall or behind the dashboard on a Stude truck. I think that’s why they designed those auto mechanics diving boards!
    When I sold my other Stude pickup, the first thing that the new owner did was fabricate a clever front-hinge system for the hood.
    SS327 likes this.
  16. bchctybob
    bchctybob
    I just looked at a little of the Cole-Hersee online catalog, wow, some great stuff in there.
  17. LOL!
    Says the man with some of the nicest "modern" kustoms around!
    Ben
  18. Nope. I have wished many times I had used a " flat fuse" panel in mine. Many come with a cover completely hiding them.
    I do like the wiring being in the open on Studebaker trucks. No under dash ****.
    Ben
  19. been a while, but...
    this pops at 400-460 degrees Fahrenheit... :p
    egads and bchctybob like this.
  20. bchctybob
    bchctybob
    I didn’t take pictures when I tore into the p***enger’s side so here’s a little “before” on the weird brakes. It looks it was a little wet on this side at one point. Didn’t get to the shoes though. The drum looks good.
    5451FA80-9158-4DEB-854B-154F3E264107.jpeg 9545AFEA-0B11-4063-930F-570D6BB220AD.jpeg
    brEad likes this.
  21. bchctybob
    bchctybob
    More weirdness. It looks like the wheel cylinders are sealed to the backing plates. At first I thought it was a rubber seal and I expected them to be in the kit with the new wheel cylinders, but it turned out to be seam sealer, like Dum Dum. Black gummy stuff. It pretty much glued them to the backing plates.
    0A7F73D2-6C50-41E4-80A2-11ED94399D6E.jpeg 79B3D38A-EF03-4DBB-99DC-589323F9FDAA.jpeg
    With the sealer s****ed off, it came apart easily.
    brEad and Rice n Beans Garage like this.
  22. bchctybob
    bchctybob
    While I was messing around with the brake drums and hubs, I got to thinking. I do not like the Mopar lug bolts, never did. They have small heads and don’t seat well in my chrome wheels. Also, I have a set of Cal Custom knock-offs that I hope to use. Especially since I spent a small fortune getting them re-plated.
    So it occurred to me to just screw some full thread, 1/2-20 Allen bolts in from the rear and use conventional 13/16 lug nuts, like I do when I change bolt patterns on stuff. I still need to verify that the heads won’t interfere with the brakes, but my initial measurements show that it shouldn’t be a problem.
    The problem is, I have no idea how the knock-offs attach to the wheels. I can certainly drill and tap the bosses in between the lug holes but I would sure like to take a look at the instructions that must have come with them. I put one on temporarily. The internal bracket flexes enough to fit the bolt pattern. The holes in the bracket are huge and fit over even the large lug nuts.
    If anyone has a set on their car, I could sure use some solid information on how they mount.
    brEad likes this.
  23. BamaMav
    BamaMav
    from Berry, AL
    Could they be designed to push through the wheel center, captured between the brake drum and wheel?
    After second thoughts, probably not. Doubt they would fit between the hub register and wheel.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    There are cone shaped washers to keep the hub cover adapter on B7E532AF-4AAD-4427-97C4-3C8EAA0AD36C.jpeg 2B0A90C7-06E3-4D0D-B959-9192A49FB67A.jpeg A3323CAB-7303-4140-8E57-DA1BDB93BC42.jpeg 3C2E18D6-9936-4294-B58C-8C06F5F23B01.jpeg F6F5C913-EE26-4ACA-822A-39DCC1E91E49.jpeg
  25. bchctybob
    bchctybob
    Of course! Simple. I can make those. Thanks!
    I’ve always liked those Cal Custom knock-offs, ever since I saw them on an ice blue mild custom ‘55 Chevy 2 dr hardtop that belonged to someone who was ahead of me in high school. The chrome wheels, 1” white walls and knock-offs just seemed like the perfect wheel combo on that car. Just after he graduated, he literally wrapped it around a pole on Lincoln Blvd near LAX. He may have been going a little fast but the city’s sprinkler had broken and flooded the street right at a big sweeping curve. We went to see it in the little impound yard and it was sad, one of the few cleanest cars around, bent in half. The hood was sprung open and it had 3x2s and a well detailed engine compartment too.
    Frankie Pisano’s shortened, 413 powered truck had them…. Love that truck.
    lumpy 63, brEad, egads and 1 other person like this.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    Best part about these is that they have never been reproduced. It is cool being the only person at an event that has em....
  27. bchctybob
    bchctybob
    Yep. But yesterday I tallied up what I have in them…. way more than the wheels themselves!
    Like you said, I’ll be the only one on my block with them, lol.
    Budget36 and Moriarity like this.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    makes the NOS set I bought at the swap meet in Wichita about 15 years ago for 25 bucks seem like a huge bargain!!
    brEad, bchctybob and RICH B like this.
  29. bchctybob
    bchctybob
    Oh, hell yes! I never see them at all these days, just the Halibrand cast aluminum things.
  30. Hitchhiker
    Hitchhiker
    Cool truck
