Customs Studebaker engine swap
Discussion in 'The Hokey Ass Message Board' started by bgthegreat, Feb 4, 2021.
  1. bgthegreat
    bgthegreat
    Has anyone put a V8 into a 51 Studebaker Champion?
  2. Hnstray
    Hnstray
    from Quincy, IL
    @bgthegreat
    ‘51 was the first year for the V8. It should be a ‘bolt in’ where the ch***is is concerned. Will need v8 mounts and V8 transmission. Champions had lighter duty brakes, springs etc.
    Studebakers used the same basic ch***is and suspension from 1951 onward, varying in wheelbase for various models. Some parts, including the ch***is were beefed a bit about ‘53/‘54 as I recall, but lots of Champs got V8 swaps with minor changes as mentioned in above paragraph.
    Ray
    kidcampbell71 likes this.
  3. Mike VV
    Mike VV
    from SoCal
    What...V-8 ?
    Sure, done all the time.
    Need to make your own front and rear mounts, need to measure for a new driveshaft.
    The small Chevy is the most installed, although obviously a Stude V-8 is a bolt in with the correct mounts.
    The 40's are of a planar design front suspension and not very good with handling.
    The later 51 to 1966 ch***is/frame is either identical or very similar. You cannot put a 51 up, front suspension on a 40's ch***is without more work than it's worth.
    A non Stude engine swap wont be a simple swap for the novice. Some experience required.
    Mike
    kidcampbell71 and Budget36 like this.
  4. bgthegreat
    bgthegreat
    Thank you guys. Are the motor mounts to put a Stude V8 in a 51 Stude a hard find? How about other Studebaker parts for that year. I already have a 63 Avanti. Sees like those parts are available.
  5. partsdawg
    partsdawg
    from Minnesota
  6. RichFox
    RichFox
    I don't know about 51 Studes. But I put a SBC in a 61 Lark and the 6 cylinder cars came with a different ch***is than the V8 cars. Lighter and made fir the six. I beefed mine for the belly ****on. When I was younger and had more cl***, I put a hemi in a 53 Champ. It also had a lighter frame than the V8 cars. So I am not to sure about just getting factory motor mounts and slapping in a 289 or such.
    Budget36 likes this.
  7. Mike VV
    Mike VV
    from SoCal
    Rich -
    Different...but the same.
    Dimensionally (except for the material thickness), the frames are the same, car to car.
    Like my 54 wagon...I pulled a flathead 6 out, turned the motor mounts around (side for side) and dropped in a 259 Stude engine, with no drilling, welding to the frame. Just two new holes in the front motor mounts.
    So, Lark to Lark, no matter the engine, 53 to 55, 53 to 55 (coupes to coupes, sedans to sedans), no matter the engine, the frames are the same, from the firewall forward. Material thickness makes no difference to the ability of bolting in a different Stude engine.
    Mike
    RAK and Hnstray like this.
  8. If I remember correctly, one of the James Bond stories had either Q or Felix Leiter driving a '53 Stude, modified into a convertible with a Cadillac V8 in it :D
  9. Found it-
    In Diamonds Are Forever, Felix Leiter picks up James Bond outside the Plaza – near the horse-cabs – in what Bond believes is a black Studebaker convertible. After Leiter gives Bond a demonstration of the abilities of the vehicle, Bond is impressed.
    “Well I’ll be damned,” said Bond incredulously. “But what sort of a car is this anyway? Isn’t it a Studebaker?”
    “Studillac,” said Leiter. “Studebaker with a Cadillac engine. Special transmission and brakes and rear axle. Conversion job. A small firm near New York turns them out. Only a few, but they’re a damn sight better sports car than those Corvettes and Thunderbirds. And you couldn’t have anything better than this body. Designed by that Frenchman, Raymond Loewy. Best designer in the world. But it’s a bit too advanced for the American market. Studebaker’s never got enough credit for this body. Too unconventional. Like the car? Bet I could give your old Bentley a licking.”
    And here's the link to "Studebaker with a Cadillac Engine" written by Wilbur Shaw
    https://flemingsbond.com/studillac/
    egads, Hnstray and stillrunners like this.
  10. stillrunners
    stillrunners
    from dallas
    Yep.....early V/8 motor mounts should not be hard to find - they used the same frame for years - just a little longer on the big cars and the later Factory Chevy mounts I think are still available thur Studebaker International - they have the bulk of the NOS stuff left over in South Bend.
  11. vtx1800
    vtx1800
    stillrunners likes this.
  12. aircap
    aircap
  13. bgthegreat
    bgthegreat
    Thanks guys, you are the best!
  14. 73RR
    73RR
  15. junkyardjeff
    junkyardjeff
    A local junkyard has a 51 with a V8.
  16. Dangerousdan
    Dangerousdan
    from Arizona
    I'm thinking a Cad 390 would be my choice.
  17. Grumps55
    Grumps55
    How about a 500 Caddy in a '54 Champion? Any thoughts on that?
