Technical Studebaker over heating
Discussion in 'The Hokey Ass Message Board' started by 32highboy54, Jan 30, 2023.
  1. 32highboy54
    32highboy54
    from southport
    I have a 289 studebaker engine that never overheated. I put a new radiator because old one started leaking. Put a new thermostat in the right way. Let the car run for 15-20 minutes and the gauge started to climb higher than it did before. Friends told me it could be a reverse flow . Was told to put the thermostat in upside down. Let the car run for 15 minutes and never overheated. Can somebody explain how that worked.
  2. Mike VV
    Mike VV
    from SoCal
    Hmm, have not heard that one before !
    But then...hot water is hot water. Thermostats rarely ocelate open and closed. Once open, they stay open until the temp. drops well below the stated temperature.
    The opening (water p***age)...hasn't changed in diameter... Sounds odd to me.
    And it being a Studebaker makes no difference. The cooling / water flow are the same as all other 50's to 80's engines (NOT...reversed!).
    Mike
  3. Bandit Billy
    Bandit Billy
    It just does. Maybe someone put a reverse flow water pump on it?
  4. DDDenny
    Did you, the first time?
  5. aircap
    aircap
    Did you ask over on the Studebaker Drivers Club forum?
  6. 32highboy54
    32highboy54
    from southport
    That is my next step
  7. 32highboy54
    32highboy54
    from southport
    It is the same water pump the car always had in it . Never overheated
  8. Budget36
    Budget36
    Can you post a pic of the thermostat you used, then point out what side went into the block that made it work properly? If it resembles thermostats that I have used over the years, the “bulb” for a lack of a better term, is stamped with the rating, that side goes into the block/intake.
  9. wheeltramp brian
    wheeltramp brian
    I'm thinking that perhaps you just had some air trapped in the system and when you swap the thermostat again it got the air out.
    Blues4U likes this.
