Technical Studebaker six transmission options
Discussion in 'Traditional Hot Rods' started by Jake lawrence, Oct 19, 2017.
  1. Jake lawrence
    Jake lawrence
    Hello, everyone long time fan of these forums, I love following the projects. I am currently working on one of my own that involves a 1954 Studebaker flathead six, really like this little motor and have begun my search for a manual transmission and starter. Apparently the original would have been a T-96 Borg warner. Am looking for one now. A friend has offered a 1963 Falcon 3 speed, a 3.03, I think. The bell housings are different. The ford is smaller with the starter on the other side. Other than that the trans looks close. I am seeking any information on possible transmission options. A jeep maybe? Etc. Any help is appreciated.
  2. RichFox
    RichFox
    I do have a 3 speed out of a 62 Lark. Actually I have the engine and trans with starter as it came out. It is pretty much the same engine, but it is OHV. Don't know where your from, but your welcome to it if you pick it up in San Mateo, Ca.
  3. Texas Webb
    Texas Webb
    Do you have the car also?
  4. Jake lawrence
    Jake lawrence
    I am in Kentucky. I only have the motor.
  5. Jake lawrence
    Jake lawrence
  6. RichFox
    RichFox
    The Lark and it's belly ****on 383 sbc along with 4 speed and 9 inch is now cruising around. On the wrong side of the road around Melbourne.
  7. RichFox
    RichFox
    Well if you find a way your welcome to it.
  8. BOBCRMAN
    BOBCRMAN
    from Holly
    I have a 60 Stude flathead six with OD trans for almost free
  9. location?
    bix six or small 6?
    WHY BE ORDINARY ?
  10. For the original post--
    I AM ***UMING YOU REFER TO A CHAMPION 170, OR 169.5 ENGINE, not the larger 245 Commander six used in some trucks-- a possibly great solution is to pull the 6 cyl 170 engine and trans from a pickup that's about to be parted out.
    It will have a V8 bellhousing that bolts to a six, a high six cyl starter location, and will give you a v8 clutch and a whole lot more transmission options than the tiny 6 cyl bellhousing will.
    You can adapt Chevy and other stickshifts easily to it, OR bolt a Stude T86 trans from a light duty v8 right in without adapting anything.
    WHY BE ORDINARY ?
    Hnstray likes this.
  11. Jake lawrence
    Jake lawrence
    Yes its the 170. Where at Bobcrman? Am checking the local swapmeets and online auctions. They are a little scarce around here.
  12. Jake lawrence
    Jake lawrence
    looking at the ford trans a friend has offered up. not really up on falcon trans. this may be an L6. but interested in whatever manual may work for me. can i adapt a bellhousing? i am aware of the t5 adapters, a little pricey.
  13. vtx1800
    vtx1800
    I've got the engine drive train out of a 53 Champion, six and over drive, I am in Iowa so shipping even the transmission would drive the price up and I would just about give to someone that could use it just to have it out of the shop.
  14. Danny G
    Danny G
    I have a 3 speed overdrive out of a 42 champion that is free plus shipping
  15. Bearcat_V8
    Bearcat_V8
    from Dexter, MI
    One thing you didn't mention is whether you have the plate that bolts to the back of the engine. This is what the bell housing bolts to. There is a difference between the plate needed for the 169CID and the later 185CID & 170CID motors.
    Also, I have never seen a T5 adaptor for these motors. Who makes them? I called Bendtsen's to inquire about it, and was given a flat NO, with no other explanation.
  16. mikeselcamino65
    mikeselcamino65
    Hey guy....mike here...I'm new but I have a 51 stude its got the original flat 6 and 3 speed and O.D.
    complete with clutch, pressure plate n all....The guy I got it from said it ran....And I mean I got the whole thing....motor, trans, starter,carb,dist.... make me a offer.... I live in Ohio... I even got the radiator
  17. plym_46
    plym_46
    from central NY
    Get one with the OD, you won't be disappointed.
  18. wuga
    wuga
  19. coilover
    coilover
    from Texas
    Have a running engine and overdrive trans from a 51 pickup. We drove it into the shop to put a Nova clip under the truck. A baby chick sounding price---cheep, cheep, cheep. IMG_4418.JPG IMG_4419.JPG IMG_4420.JPG
  20. Dan Locke
    Dan Locke
    Rich do you still have this? I realize the thread is ancient... fingers crossed!
  21. Dan Locke
    Dan Locke
  22. Dan Locke
    Dan Locke
    You still have this? Location?
  23. Dan Locke
    Dan Locke
    Do you still have this?
  24. SS327
    SS327
    Rich Fox p***ed away some time ago.
