Stuff you've learned the hard way
Discussion in 'The Hokey Ass Message Board' started by 57JoeFoMoPar, Jul 19, 2008.
  1. jay
    jay
    A car running a magneto will not shut off without the proprer kill switch hooked up(that means its own toggle switch)...before mentioned car will also come to life on only a bump of the remote starter switch and proceed to try and make its own road whether the owner is ready or not...thus creating alot of body work on the front end that wasnt needed before hand
  2. NOTCH
    NOTCH
    Make sure you mix bondo with hardener before you spreed it on the hole side of your car..
    Make sure you cleen up your primer gun when finished using.
    never laugh at your buddy that got metel in his eye from grinding, cause it will happin to you the next day.
  3. Bodacious
    Bodacious
    When removing the stuck piston from a caliper by using compressed air, make sure none of your ****ing fingers are in it's path of exit.....
  4. btbsandman
    btbsandman
    There is a reason for a seat belt and health insurance, that mistake cost me about $60k in hospital bills and my life almost.....
  5. Wildfire
    Wildfire
    Great Stuff - that spray foam in a can. It doesn't come off your hands with anything except sandpaper or a pocket knife.
    I have now learned this at least 3 times. Including right now.
  6. Mudslinger
    Mudslinger
    All engines run good before they lock up tight!
  7. oilslinger53
    oilslinger53
    from covina CA
    some mopars have a different kind of lug nut for each wheel. i thought the all the p***. side lugs were stuck on the 60 savoy, and i broke every one of them off. it wasnt till i got new studs and tried to put the wheel back on that i discovered they are indeed left hand thread....
  8. Da Tinman
    Da Tinman
    Putting the steering wheel in the absolute most comfortable driving position, will make it impossible to get in or out.
  9. panhead_pete
    panhead_pete
    Your pants will actually catch fire when you have your leg in the line of fire when grinding.......twice :)
  10. Irish Dan
    Irish Dan
    SAFETY FIRST!..........at all costs. That includes SAFETY GL***ES!....could of saved myself a few hundred dollars at the Emergency Room on that one! NEVER ***ume the neutral safety switch will do what it was designed to do!...it's always best to check to see if you're in a gear or not! NEVER go ANYWHERE without a fully functional FIRE EXTINGUISHER!.....my 2 cents only.
  11. Nitrofan
    Nitrofan
    from Kentucky
    Don't stand in front of the shop press when pressing off axle bearing, you have better luck standing in front of load gun.
  12. Fraz
    Fraz
    from Dixon, MO
    Put the water p***age adapter on an Edelbrock FE intake BEFORE you bolt the intake down on the motor and block the hole with the waterpump.
  13. Flynn's_57
    Flynn's_57
    from Nor*Cal
    Shops are there to take your money, not realize your dream (no matter how cool and unique it is).
  14. kiwiboy
    kiwiboy
    1. Don't arc weld if you have holes in your boots
    2. A heavy wire brush on a 4" grinder is dangerous
    3. Gearbox's/motors are easier to get in with help
    4. "It won't take long" is a long time
    5. Safety is underrated
    6. It always cost more
  15. Unkl Ian
    Unkl Ian
    And the ****ing genius that is going to show you
    how to "correctly remove" chrome window trim
    with a big screw driver is one of those 9.
    ***hole.:rolleyes:
  16. THR1LL3R
    THR1LL3R
    from St. Louis
    buying a car I knew nothing about, then found out I bought it frond a hack
  17. Unkl Ian
    Unkl Ian
    ...and takes longer;plus the idiot complaining
    about it has no idea of what is involved.
  18. Crosley
    Crosley
    from Aridzona
    If this slips...it's gonna hurt.
  19. primed34
    primed34
    Cheap **** is just that. Never use a bench grinder with out tighting the grinding wheel.
  20. Specialdeluxe
    Specialdeluxe
    Take care when storing parts you obtain for later use, or you'll end up tracking down and buying a lot of parts a second time.
  21. D Staig
    D Staig
    Second that.
  22. olskool37
    olskool37
    1: Never "think" you know whats wrong
    2: Dont spend money on a part you dont need (see #1)
    3: Its ok to feel like a dip**** after you found out whats wrong.... i.e. having the wires on the dizzy cap, one position off.... found this after weeks of trying to get an engine to start... one new part at a time
  23. PeteFromTexas
    PeteFromTexas
    I just learned not to brink beer and do donuts on a 4 wheeler in the dark...Flipping one of those things ****s. I'm in pain.
  24. dabirdguy
    dabirdguy
    To estimeate the time it takes to do a job:
    Make your best guess
    Double it
    Increase the unit of measure by 1
    So... a 3 week project will probably take 6 months.
  25. olskool37
    olskool37
    OOOhhhhh, now it all makes sense A month or two, doubled, then the unit thing..... = @ 3years!
    I got it!!
  26. Parts48
    Parts48
    from Tucson, Az
    Not to open threads.."Look at it" !...
  27. budd
    budd
    make dam sure all the needle bearings are in there correct place before installing a u-joint, never think you can get by with one less needle bearing in a u-joint, hammers and u-joints dont mix well.
  28. The Cap'n
    The Cap'n
    from Kansas
    Most recently...
    It's never a bad idea to get a second pair of hands to help lift something awkward and heavy
    Jack stands can't hold everything
    Middle fingers don't belong between an axle and a jack stand
  29. elwood blues
    elwood blues
    Never try to jack a full mock up of a car when the frame is just tacked together.....I know I'm dumb
  30. Roadsters.com
    Roadsters.com
    Look at the bright side. At least your name isn't Pete.
    Dave
    http://www.roadsters.com/
