Stuffing a Rust Hole!
Discussion in 'The Hokey Ass Message Board' started by The Blurr, Feb 20, 2008.
  1. The Blurr
    The Blurr
    Today I just recieved a patch panel for my 1960 T-Bird. The left front fender had a big rust hole in it. The previous owner stuffed it full of bondo. So now I am going to cut it out and replace it with steel. Does anyone have any tips, suggestions as I have never done this before.:eek: Any help would be awesome!
  2. brokenspoke
    brokenspoke
    First thing I would do is vote your city council out of office..
  3. converseandbowlingshirts
    from Eugene, OR
    The rust has probably weekend the metal out past the area where it's obvious. Make sure you have enough healthy metal to weld to by checking out the back side of the chunks you cut out. Also, prep the metal well by removing all rust and scale before you start welding the new panel in.
  4. And if you can, work with the body seams. They hide screw-ups better than flat panels.
  5. pimpin paint
    pimpin paint
    from so cal
    Hey blurr,
    A photo of your problem area, on the fender, would be a great
    help in givin' advise-
    What kinda welding equipment do you have to work with? This is
    going to have alot to do with where you cut out and reweld the
    rusted area. Can you tell, are the patch panels any where close to
    looking like they'll fit without major rework? This is usually the case
    with most patch panels on the market, not all though!
    S****ey Devils C.C.
    "Meanwhile, back aboard The Tainted Pork"
  6. The Blurr
    The Blurr
    UH Uh.... Then what?
  7. The Blurr
    The Blurr
    Right On. I will try to get pics up tonight. Thanks
  8. the shark
    the shark
  9. Just Gary
    Just Gary
    1. Use the search function. Key words: patch panel, welding sheetmetal, warping.
    2. There are several good tech threads; "a patch panel from start to finish" is one that comes to mind.
    Good luck and post some pics!
