Technical Stumbles When Applying Brakes - HELP!
Discussion in 'Traditional Customs' started by Indetrucks, Apr 24, 2015.
  1. greybeard360
    greybeard360
    That channel across the front of the spacer is a heat p***age that exhaust g***ses p*** thru. Where the exhaust comes out of the manifold and into that p***age...... plug those holes!
  2. Indetrucks
    Indetrucks
    Is there a specific or preferred way to plug em up?
  3. Engine man
    Engine man
    from Wisconsin
    They can be plugged with core plugs or you can tap them for a pipe plug or tap to a bolt size, cut off a piece of bolt and cut a slot in it to screw it in. Stake the thread lightly so it doesn't work lose.
  4. greybeard360
    greybeard360
    An alternate method (although I don't like this many gaskets under a carb) is to use a factory gasket with the slot in it on the manifold, the stainless plate, a standard flat gasket (or a slotted one, doesn't matter) then the spacer and finaly a gasket, then the carb. Either method works, main thing is to get the exhaust gaskets out of that spacer. At this point you could use some JB to fill the crack and low spots and re-use the original spacer if you can't find a good subs***ute.
    More than one way to skin a cat .... and the make fine taco's either way :)
  5. 1932tub
    1932tub
    Have you managed to remedy the fault and if so what was the problem?
  6. Indetrucks
    Indetrucks
    Well, I installed the new riser plate and the problem still exists. I am honestly at a loss.
    I think rebuilding the carburetor will be my last attempt at fixing the problem myself. If that doesn't work, maybe time for a shop to diagnose it.
    Maybe the darn engine needs a rebuild after all? Low compression could cause the low vacuum I suppose, but there is no smoke from worn rings whatsoever. She does run rich though
  7. canning
    canning
    Leak in diaphram of carb dashpot/powervalve? Are you measuring vacuum at intake or port on carb?
  8. BJR
    BJR
    It is also possible in an old engine like that, that the timing chain has stretched and has jumped one tooth, thus retarding the cam. That will give you low vacuum and could be your problem. I have had a few 50's, and 60's cars that the timing chain has jumped on or was about to jump when I replaced it. If you remove the distributor cap so you can see the rotor move, you can see if the timing chain is stretched. Remove cap, turn the engine backward by hand until the rotor starts to move. Mark the dampener with tape or chalk, and now turn it forward just until the rotor starts to move. If it's more then 1/4" on the dampener the timing chain is bad, and may have already jumped a tooth.
    hacknwhack likes this.
  9. junkyardjeff
    junkyardjeff
    You might want to look at the coil,I had them act crazy when starting,stopping and going around corners when the oil inside it gets low.
    oldsrocket likes this.
  10. Andy
    Andy
    You said it only happens when appling the brakes. The only thing in common with the engine and the brakes is booster. It will draw in brake fluid if the master cylinder leaks. The engine will run bad with the added brake fluid. I know you said the master cylinder was new but it can still leak. The exact thing happened to me and it was fixed with a better m/c.
  11. sunbeam
    sunbeam
    When adjusting the carb Turn the idle air screw in until you get the RPM you want then adjust the mixture screws to get the highest RPM or vacuum. then turn the Idle air screw in to reset idle then repeat. The idea is to get the idle air screw in as far as you can and still have the right idle RPM.
  12. Andy
    Andy
    Does it stumble when you apply the brakes when it is not moving?
  13. 1932tub
    1932tub
    My bet would be the coil, the primary winding has come loose and when you put the brakes on it shorts out on the case cutting the ignition, swap it out and see what happens.
    Atwater Mike likes this.
  14. Atwater Mike
    Atwater Mike
    1932tub, in 1957 I was an apprentice at the 'Best damned garage in town', Mayfield's in Santa Clara.
    The old man diagnosed a Chevrolet 216 problem as the winding 'floating' inside the coil...Sure as you live, he replaced the coil: instant repair. Red was sharp...
  15. 1932tub
    1932tub
    I learned that from an old hand as well Mike
