Technical Stupid (but good) trick # 6
Discussion in 'The Hokey Ass Message Board' started by nochop, Jun 24, 2024.
  1. nochop
    nochop
    from norcal
    While scratching my head on how to replace my coil over bushings I came across this doh! I thought I’d share
  2. Bcap55
    Bcap55
    from PA, USA
    Cool thanks for sharing that. I like how you can get the string out when it's done.
    Sharpone likes this.
  3. nochop
    nochop
    from norcal
    I’m not a burly as that guy, I tied a not to make a loop an used a pry bar and levered it in
    Sharpone, clem and brading like this.
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I have used that method and it worked amazingly well. But to get them in with even less stress make the nylon cord long enough to have the loop hang low enough to get your foot into it. Then, just stomp your foot down abruptly and the bushing will snap in.
    Kinda like how you shear metal in a jump shear.
    Cheers
  5. bobss396
    bobss396
    I would at least have worn a good pair of work gloves, but a good method for sure. His hands had to be sore after the first 2 bushings were in. Me trying it on my own, it would involve a screwdriver and 2 stab wounds to my hands.
    vtx1800, alanp561, Sharpone and 6 others like this.
  6. MMM1693
    MMM1693
    Hell of a idea.
    Sharpone and nochop like this.
  7. Dishwashing detergent is even better than WD40 on these things.
  8. ALLDONE
    ALLDONE
    I had to do this yesterday,... I'd have to borrow a set of arms and hands to do that way... cool though...
  9. tombstone
    tombstone
    from sk.canada
    I looped the cord on a short prybar and was able to get some leverage off my workbench to pull down and they snapped in place . It’s great idea , works like a damn ‼️
  10. Beanscoot
    Beanscoot
    Dishwashing detergent is somewhat corrosive over time, so an oil base lubricant is better. A tiny bit of rubber grease might be even better.
    Sharpone, bobss396 and Desoto291Hemi like this.
  11. bobss396
    bobss396
    Like a swimming pool o-ring lube.
  12. belair
    belair
    If it works, it ain't stupid.
    Sharpone and bobss396 like this.
  13. nochop
    nochop
    from norcal
    That’s how I did it
  14. nochop
    nochop
    from norcal
    Anymore stupid tricks out there?” Feel free to list them here
  15. Sharpone
    Sharpone
    I keep a bottle of Astro Glide in the shop for such occasions. The wife gave me one of those looks at first, until she watched me slide a hose on effortlessly lol
    Dan
    Driver50x and Illustrious Hector like this.
  16. alanp561
    alanp561
    I must live too far back in the hills, but I had never heard of Astro Glide until your post. Naturally, I had to Google it. What made you think a tube of personal lubrication product in your shop would be handy? Asking for a friend.
  17. Illustrious Hector
    Illustrious Hector
    On or in? My wife gives the same treatment because of Vaseline in the parts cabinet. ASTRO glide would be too blatant.
    nochop and Sharpone like this.
  18. JD Miller
    JD Miller
    Astroglide eh? :eek:
  19. Sharpone
    Sharpone
    Works for every other tight fit I’ve had lol
    Dan
    nochop likes this.
  20. theHIGHLANDER
    theHIGHLANDER
    If ever there was a job for the latest internet star...:eek:
    500 bonus puts for the 1st one to quote her...:)
  21. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Well, I have posted this before, but it's one of my favs.
    The top nut on a shock absorber spinde refuses to loosen, causing the whole shaft to turn.
    Find a tight fitting deep socket. If needed use an adapter for a half inch extension.
    Want two feet length or better. Proceed to pull and push back and forth.
    As the rhythm picks up it gets easier 'til the shaft lets go and breaks.
    I have also used this on a lug nut that wanted to turn the axle stud.
    ( cross threaded or rusted, what have you ).
    Here, for leverage, I used a tubular Jack handle.
    Remember to keep the swing on the same plane each time.
    The remains of the stud will be easily knocked out as well.
    Driver50x, nochop and Sharpone like this.
