Stupid flathead question
Discussion in 'The Hokey Ass Message Board' started by pushrod_mike, Nov 29, 2010.
  1. pushrod_mike
    pushrod_mike
    from Austin TX
    I have a fathead I got in the 40 Ford coupe I am redoing. It has a stock aluminum intake. Is this normal?
    Oh yea it also developed a hole after soda blasting on the riser neck for the carb. Small about 1/8" dia. Alright to patch it?
    What is this intake by the way?
  2. eaglebeak
    eaglebeak
    On '49 to '53 Canadian flatheads, the intake and timing cover was aluminum.
    You should try to put a picture up for us to see.
  3. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    wasn't the oil pan aluminum also on the Canadian versions? wait that maybe the french can't remember.
    EDIT- It was the french blocks with the aluminum pan, my bad
    post pics that will help us identify it
  4. pushrod_mike
    pushrod_mike
    from Austin TX
    OK here are some pics. See the little hole on the neck? Also a pic of the numbers on the head. I know I know I'm a flathead idiot but thats just who I am.
  5. pushrod_mike
    pushrod_mike
    from Austin TX
    Nobody knows what this is? Come on you guys are holding out on me.
  6. DD COOPMAN
    DD COOPMAN
    '46-'48 heads. '36 or so intake. JB WELD the intake...it'll work. DD
