Stupid Ford Flathead Clutch question....
Discussion in 'The Hokey Ass Message Board' started by Hitchhiker, Aug 27, 2012.
  1. Hitchhiker
    Hitchhiker
    I feel Like I am missing something.....What pulls the throw out bearing and the pedal and such back?
  2. Bruce Lancaster
    Bruce Lancaster
    When asking flathead stuff, always include some info on year of engine, trans, ch***is, etc. as there is a lot of variety...
    but basically a spring pulls the sliding casting that supports the throwout bearing back away from the clutch fingers, and a spring on the clutch pedal down around the fulcrum or attached directly to the pin connecting to rod keeps the pedal up against the floorboard so its weight does not push agains bearing carrier.
    Look at the '48 Ford stuff, http://www.vanpeltsales.com/FH_web/FH_images/FH_trans-pics/Flathead_Clutch***y_1940-48_85hp.jpg parts 7562 and 7523
  3. Hitchhiker
    Hitchhiker
    Thanks Bruce. I have the spring on the pedal, but not the throw out bearing.....Back apart it comes.....46 59ab and a 39 toploader in a AV8 for what its worth.
  4. prewarpete
    prewarpete
    You should be able to put the spring on through the little inspection panel on the top
  5. thunderbirdesq
    thunderbirdesq
    Yea, it's just a little ****** of a spring, a pair of forceps/tweezers/needlenose should do it.
