Stupid Model A Question
Discussion in 'The Hokey Ass Message Board' started by Mule Farmer, Aug 7, 2005.
  1. Mule Farmer
    Mule Farmer
    from Holland MI
    where is the vin number on the frame.
    thanks bret
  2. Volksrod
    Volksrod
    You'll find it under the cowl on top of the frame rail on the drivers side. There should be a star in front of and behind the number.
  3. Mule Farmer
    Mule Farmer
    from Holland MI
    couldent find it there any other places it may be.
    bret
  4. sodbuster
    sodbuster
    from Kansas
    If it is stock it is on the engine. Otherwise it is on the frame, drivers side about 4-6 inches back from the front of the cowl. You will have to lift the body off to see it. Also, you could use some 0000 steel wool to try to polish the "Stamp" out.
    Chris Nelson
    Kansas
  5. coupeHEAD
    coupeHEAD
    That's only if, it is the original engine, will you find it to be the exact vin number of the car and will match the frame rail as mentioned.
  6. Automotive Stud
    Automotive Stud
    I've heard that not all A's had vins stamped in the frame, so you might be looking for something that isn't there.
    Plus the vin is only going to be about 6 or 7 digits, I forget exactly.
