Stupid SBC Starter Question
Discussion in 'The Hokey Ass Message Board' started by AcadianKid, Mar 29, 2010.
  1. AcadianKid
    AcadianKid
    I have a Delco Remy(part#1109064) starter that came with a motor I purchased. I had it tested and works fine. However I want to make sure it'll work with my flexplate. Can someone tell me what number toothed plate this one will fit? I have done a search here as well as gone to delcoremy.com and ran the part number, says its invalid. I was hoping someone here had a reference book or another idea
    Thanks in advance
    Cory
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    More info needed. GM mini style, Straight or Stager bolt pattern ?
  3. are the mounting bolts straight across or staggered? straight is 153, staggered 168
  4. Deuce Roadster
    Deuce Roadster
    There are two basic types ...
    1 ) a 153 tooth flywheel which uses a straight across pattern starter
    2 ) a 168 tooth flywheel ... which uses a staggered pattern starter,
    Count the teeth on your flywheel and then check the pattern on your starter :)
  5. AcadianKid
    AcadianKid
    Thanks its staggered, the other numbers on it are p3510s
  6. make sure you use the correct bolts
  7. Deuce Roadster
    Deuce Roadster
    Count the teeth on the flywheel ( you need 168 teeth ) and
    Like 36-3window says ... use the correct bolts.
    I buy mine at the Chevrolet dealer ... but most speed shops have them ARP makes a NICE set ... which the speed shop can get.
    Summit Racing has them also.
  8. TomWar
    TomWar
    When I was having trouble with a SBC starter engaging properly, I went to Advance
    Auto(Discount) and pulled all of the GM starters out on the floor. I think there are about 12-13 different configurations. I Knew how I wanted it to mesh, and picked out the right one, NO more trouble.
  9. brady1929
    brady1929
    more great info here
  10. Duyu Remember
    Duyu Remember
    from So. Cal
    Another way to see what's what.......
    On starters made B4 about 1981....10MT series...
    Housing bolt SHANK is .375" (3/8") with 3/8 NF threads
    Aluminum nose housing
    2 long bolts = use with a 168 tooth flywheel/flexplate
    1 long & 1 short bolt = use with a 153 tooth flywheel/flexplate
    Cast iron housing
    1 intermediate and one longer bolt = 168 tooth (U wont find many of these around)
    1981 or so and later ar METRIC starters...that is they used metric screws (sometimes).......
    Housing bolt shank is 10MM (.395") with 3/8" NF threads
    The bolts DO NOT INTERCHANGE. Measure the holes in the nose housing. Use the correct bolts.
    At the end of the day give the 10MT the flotation test and then use a PMG (permanent magnet) style late model GM starter.
  11. 53sled
    53sled
    from KCMO
    It will be very obvious if it is wrong. 12 3/4" v 14 1/8" diameter
  12. Deyomatic
    Deyomatic
    from CT
    What difference do the bolts make?
  13. dave lewis
    dave lewis
    from Nampa ID
    The starter housing is drilled to use the 10 mm bolts .
    10mm is slightly larger than 3/8 ".
    You cannot put 10 mm bolts into a 3/8" housing
    BUT you can put 3/8" bolts into a 10mm housing,
    causing the starter to move around and eating up your flexplate !
    #3510
    OR 3510M...
    be careful !
    Also, just a heads up..The permanent magnet GM starters all seem use 10mm bolts....
    Just a heads up from an old , retired parts man..
    Dave
  14. nutajunka
    nutajunka
    Plus that knurling on the end towards the threads help keep the starter nose from moving, since knurling increase's the size of the bolt slightly.
  15. Deyomatic
    Deyomatic
    from CT
    Wow, I asked because I just put a 3/8 co**** thread bolt in one of the holes and it seemed to work fine. MY problem was the aforementioned issue of the two different starters. I thought they would all be the same after say 1963 or so. Boy was I wrong.
  16. dave lewis
    dave lewis
    from Nampa ID
    Deyo, the std 3/8 co**** bolt will work , BUT....
    you need the knurl down at the base to locate the starter precisly where it belongs.
    The knurl extends up into the block about 3/8" (there is a machined recess) and fits the starter housing very tight..
    This is why I mentioned the difference between the metric and std bolt diameter.
    Using a metric housing with the 3/8" will allow the starter to walk around.. As will using a std 3/8" housing with NON knurled bolts..
    Dave
